kenhsu Posted June 20, 2014 Report Share Posted June 20, 2014 Win7筆電 2代i5 記憶體8G 硬碟500G !桌面圖示中有紅色驚嘆號,使用Wise PC 1stAid還是無法修復! Operating system:Windows 7 Home Premium (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 8097 MB CPU: Intel® Core i5-2410M CPU @ 2.30GHz Drive Info: C: 235.86 GB D: 204.89 GB F: 25.00 GB Internet Explorer: 11.0 Link to comment Share on other sites More sharing options...
xilolee Posted June 23, 2014 Report Share Posted June 23, 2014 translated from Chinese: Desktop icon has a red exclamation point Win7 laptop 2nd generation i5 Memory 8G HDD 500G! Desktop icon has a red exclamation point, use Wise PC 1stAid still can not fix! That's cute, anyway. 1) Try to launch sfc /scannow from an elevated command prompt (windows installation cd could be necessary), wait until it finishes (20-40 minutes), and report the final result here. 2) (if previous point didn't work) Add the following lines to your windows registry: save the lines in a text file, save it as a .reg file, double click it, click always ok. Windows Registry Editor Version 5.00 [HKEY_CLASSES_ROOT\lnkfile] "IsShortcut"="" [HKEY_CLASSES_ROOT\InternetShortcut] "IsShortcut"="" [HKEY_CLASSES_ROOT\piffile] "IsShortcut"="" [HKEY_CLASSES_ROOT\WSHFile] "IsShortcut"="" [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Shell Icons] "29"=- 3) (if previous point didn't work) sevenforums.com: Shortcut Arrow - Change, Remove, or Restore Link to comment Share on other sites More sharing options...
kenhsu Posted June 26, 2014 Author Report Share Posted June 26, 2014 Win7 桌面捷徑圖示本來有紅色驚嘆號,用此軟體修復後變灰色! 偶的Win7 筆電桌面捷徑圖示有紅色驚嘆號,之前用貴公司的軟體修復還是無效,如今再使用一次修復本來圖示是 Operating system:Windows 7 Home Premium (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 8097 MB CPU: Intel® Core i5-2410M CPU @ 2.30GHz Drive Info: C: 235.86 GB D: 204.89 GB F: 25.00 GB Internet Explorer: 11.0 Link to comment Share on other sites More sharing options...
xilolee Posted June 26, 2014 Report Share Posted June 26, 2014 translated from chinese: Win7 desktop shortcut icons would have been a red exclamation point, becomes gray after using this software fix! Even the Win7 laptop desktop shortcut icon with a red exclamation point, use your company's software prior to repair or invalid, now used once again to repair the original icon is What fix have you used? Link to comment Share on other sites More sharing options...
