wisecleaner_admin Posted June 18, 2014 Report Share Posted June 18, 2014 Dear All users, In order to make the newly released Wise Care 365 v3 more efficient and perfect, we encourage each of you to write down the suggestions on how to both improve our product and our customer services. We will provide the free license keys for the users whose suggestions we choose to implement. The valid date of the license key is about half a year. If you are already a Pro version user, we will extend your expiry date as a reward. I know the best ideas come from our users, and I look forward to your suggestions. Please email to [email protected]. EdwinBaw, Jayzx, AppeptGause and 6 others 9 Link to comment Share on other sites More sharing options...
xilolee Posted July 1, 2014 Report Share Posted July 1, 2014 I'm using Windows 8.1, update 1, x64 I found some incongruences (bugs?): 1) With the firewall disabled, Wcare365 tells that the firewall is disabled and, after the fix, it tells that the firewall is enabled... But Windows says it is not. 2) After the fix, some histories are yet present in MSIE 11 3) With the firewall enabled (I'm blocking every outcoming/outbound connections, except few rules that I created for a bunch of programs), if I check for updates, the program tells "Congratulations, the version you are using is the latest one!"; but if I disable the firewall it could check and find new Wcare365 updates. The same applies for the other Wise Tools. It could be nice if the program says that the firewall is blocking it and that it can not check for updates. Disable the firewall or configure it --- I didn't find a way to configure the firewall for Wcare365, I'll admit! Even if I created two rules for it (inbound/outbound), without port restrictions... Is there any method that I missed? Link to comment Share on other sites More sharing options...
xilolee Posted July 2, 2014 Report Share Posted July 2, 2014 Serenator's feature request: Hello Admin,[...] Accessible windows are information about: Junk files, Registry error, Traces counted, Privacy records and Tuneup count. Is there the possibility of cleaning up these data? Many greetings, Serenator Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted July 3, 2014 Author Report Share Posted July 3, 2014 immagine.jpg immagine2.jpg You need to restart system. immagine3.jpg We will fix it soon. About the firewall issues, thank you for your suggestion. We will consider it. Link to comment Share on other sites More sharing options...
xilolee Posted July 3, 2014 Report Share Posted July 3, 2014 You need to restart system. It doesn't seem necessary to me... Anyway, the (inexperienced) user should be informed about this. Link to comment Share on other sites More sharing options...
PWT1000 Posted July 19, 2014 Report Share Posted July 19, 2014 It's been nice to see some of the suggestions made about version 3 a few weeks back have been implemented - Thank you ! Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted July 21, 2014 Author Report Share Posted July 21, 2014 Thank you for your feedback and suggestions, to help us to improve wise care 365! Link to comment Share on other sites More sharing options...
Serenator Posted August 6, 2014 Report Share Posted August 6, 2014 Hello! I noticed differences in colour fonts of buttons name in current version. You can see one of them on screenshot. There are more such examples. Can you check all and fix it to the next update? All fonts in blue? This looks more nicely and is more readable Thanks so much! Best regards, Serenator Link to comment Share on other sites More sharing options...
tipstir Posted August 6, 2014 Report Share Posted August 6, 2014 How about this PC Checkup does check and clean. Why can't we have that take care of everything. Registry Cleaner Common Cleaner Advanced Cleaner Memory Optimizer Defrag HDDs Even if PC Checkup is suppose to take care of these manual task, I find running these 5 an additional steps. Wise Care should runs these also. Super Clean Feature. Still have these features as you are now but a Super PC Clean for those who want it taken care. I run Microsoft Media Center 24/7 on this laptop PC where I am typing this from. There is bug in DRM know bug but they never fix it. I wrote a small script for it. If this could be added to a function of Wise 365 would be excellent. Thus I don't have to run when I get DRM error under Netflix. The old code is not needed because new code wipes out what's in that folder that gets corrupted in time. I just showing both codes. See attachment called MCE Fix.txt Also one more thing if we can incorporate and remove all adware cookies that seem to get past most browser cookie guards would be ideal. I can provide such data. See attachment called Bad Cookies 2014.txt and Bad Cookie 28 - 2014.png. MCE Fix.txt Bad Cookies 2014.txt Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted August 7, 2014 Author Report Share Posted August 7, 2014 @Serenator, Those options (Recommended, Select All, Select None) control scanning result (not control scanning items). They will highlight when scanning is finished. Link to comment Share on other sites More sharing options...
Serenator Posted August 8, 2014 Report Share Posted August 8, 2014 Really! I did not turn on this the attention earlier! I apologize for confusion! I great warmly, Serenator Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted August 20, 2014 Author Report Share Posted August 20, 2014 @tipstir, Remove adware cookies, it is a good idea. We will consider it, I think you will see it soon. Link to comment Share on other sites More sharing options...
tipstir Posted August 21, 2014 Report Share Posted August 21, 2014 @tipstir, Remove adware cookies, it is a good idea. We will consider it, I think you will see it soon. Thank you! Link to comment Share on other sites More sharing options...
Jayzx Posted September 4, 2014 Report Share Posted September 4, 2014 Can the PC Checkup, Common Cleaner, and Advanced Cleaner have autoclean setting or enable/disable, like in scheduled cleaning? Link to comment Share on other sites More sharing options...
Jayzx Posted October 6, 2014 Report Share Posted October 6, 2014 Can the PC Checkup, Common Cleaner, and Advanced Cleaner have autoclean setting or enable/disable, like in scheduled cleaning? Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted October 14, 2014 Author Report Share Posted October 14, 2014 @Jayzx, PC Checkup clean part of Registry Cleaner/Common Cleaner, contains System Optimizer/Privacy Eraser. Only PC Checkup has schedule task feature. Link to comment Share on other sites More sharing options...
Jayzx Posted October 17, 2014 Report Share Posted October 17, 2014 @Jayzx, PC Checkup clean part of Registry Cleaner/Common Cleaner, contains System Optimizer/Privacy Eraser. Only PC Checkup has schedule task feature. Hi, Yes I know, sorry for being confusing but I'm suggest that PC Check-up also should have auto-clean enabler setting without scheduling a clean, the same goes with Common Cleaner and Advanced Cleaner. For time-saving reasons. Will be glad if this suggestion would be recognized and approved. Thank you! Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted October 20, 2014 Author Report Share Posted October 20, 2014 Do you means you only need to click the button, then it will scan and clean automatically. (currently, you need to click two times, click to scan and click to clean) Right? I'm not sure it is a good ideas, I think most users want to check scanning result. Thank you for your suggestions. Link to comment Share on other sites More sharing options...
Jayzx Posted October 20, 2014 Report Share Posted October 20, 2014 Do you means you only need to click the button, then it will scan and clean automatically. (currently, you need to click two times, click to scan and click to clean) Right? I'm not sure it is a good ideas, I think most users want to check scanning result. Thank you for your suggestions. Right. I suggest there that a setting or enabler/disabler is to be present for users choice. Link to comment Share on other sites More sharing options...
techreg Posted December 8, 2014 Report Share Posted December 8, 2014 In Previous versions, WiseCare365 contained an option in setttings to 'Minimize to System Tray'; or if you unchecked it, WiseCare would exit and close completely.This was a very useful feature, in that most people dont want your app or anyone else's, running constantly in the background consuming resources all day/night. In the latest version(s) this option has been removed and forces WiseCare to always minimize to the tray when exit button is pressed. Giving users options and flexibility is what makes software great.So it is hard to understand why you would take the time to remove this option from WiseCare. So now to completely exit WiseCare, you must hit the close button in the upper right corner, Then mouse all the way to the bottom of the screen to find the wisecare app in the system tray, then Right click the system tray app, and click exit. This seems needlessly excessive. Please consider re-adding the minimize or exit option back in future releases. Thank You Link to comment Share on other sites More sharing options...
payne Posted January 1, 2015 Report Share Posted January 1, 2015 which version are we? on the website it says 3:35 but when I downloaded the product for the assistance of a PC gives me 3:41 Luannaapozy, GregoryWak, LillianJiX and 4 others 7 Link to comment Share on other sites More sharing options...
payne Posted January 2, 2015 Report Share Posted January 2, 2015 ok now and the section was updated, I made my compliments assistance to two pc in bad shape, after removing many viruses have used wisecare now going very well Link to comment Share on other sites More sharing options...
payne Posted January 4, 2015 Report Share Posted January 4, 2015 version 3:41 when cleaning the registry I get out a message written in Japanese or Chinese .... on my PC and other PC !!!! Link to comment Share on other sites More sharing options...
xilolee Posted April 14, 2016 Report Share Posted April 14, 2016 Old topic. Closed and unpinned. Link to comment Share on other sites More sharing options...
