mastervbguru 3 Report post Posted June 10, 2014 All: I upgraded from Wise Registry Cleaner 8.11.533 to 8.11.534. When I click on Settings and UNCHECK the "Auto Get Newsletters" checkbox, the next time I load Wise Registry Cleaner, this checkbox is CHECKED again. It does NOT save my setting (i.e. UNCHECKED. I reverted back to release 8.11.533; this version DOES save the state of this checkbox correctly. Please advise. 3 Minagaipt, Codilayeri and AntoinePn reacted to this Share this post Link to post Share on other sites
xilolee 511 Report post Posted June 10, 2014 I'm using the latest version and that checkbox remains unticked (but I'm using the portable version).win 8.1, update1, x64, c:\windows(WRC inside desktop\applications\wise portable programs\wrc)Check if your Windows current user has got all the needed permissions on c:\program files (x86)\wise registry cleaner folder. You can also try to change the config.ini: News=0 (the program must be closed before editing the config.ini). Share this post Link to post Share on other sites
mastervbguru 3 Report post Posted June 10, 2014 I am logged in as Administrator (i.e. the TRUE Administrator) account. This is the first version that I noticed that this value is not "holding". When I revert back to the prior portable version, it works fine. Share this post Link to post Share on other sites
xilolee 511 Report post Posted June 10, 2014 Well, if you continue to get this problem and want it corrected, you should provide at least informations about your OS (otherwise how developers could correct it?). Share this post Link to post Share on other sites
mastervbguru 3 Report post Posted June 11, 2014 My apologies for not including that. I am running Windows 7 Ultimate (x64) SP1 with all Windows Updates applied. Share this post Link to post Share on other sites
wisecleaner_admin 1,338 Report post Posted June 11, 2014 I have test it. But wise registry cleaner 8.12.534 can save my settings. Please try to uninstall, then reinstall 8.12.534. If you still get this problem, please let me know. Share this post Link to post Share on other sites
