Linkin
How to stop your wireless connection from dropping without rebooting the router ?
Here’s the scenario: you’re sitting on the couch, feet propped on the coffee table with your laptop in hand. You’re feeling sanguine so you load up a few HD 1080p videos on YouTube. Then you fire up Spotify and…. bam – you’re unceremoniously disconnected from the web.
What the heck just happened? Usually, you’ll just get up (or bark at your wife) to reset the router. But this is beginning to happen more frequently and you want to find the root cause so you can permanently eliminate this problem.
If you’re constantly rebooting the router then here are 2 tips that will almost certainly fix the problem:
Check WiFi Power Settings
Some wireless adapters will go sleep after a certain period of inactivity.  This is particularly a problem on laptops that are running on battery power.
Your computer probably comes with a preinstalled power manager program that you never use.  You can try to find that on your system or  just click Start then type change when the computer sleeps
I’ll show you how to get there in Windows 7 but the process is almost identical for Vista and similar for Windows 8 and 8.1.
When the power settings screen appears, choose Change advanced power settings in the bottom left corner.
Go down to Wireless Adapter Settings, expand Power Saving Mode and change the plan to Maximum Performance for both On battery and Plugged in.
Update WiFi Driver and Router Firmware
If the connection is still randomly dropping you should go to the wireless routers support page and update the firmware.
AsusD-LinkNetgear, and Medialink (my favorite) are some popular WiFi router manufacturers.
You can update your WiFi driver by clicking the Windows icon in the lower left corner of the screen and typing  this phrase:
windows update
After this your connectivity should return to normal.
The Bottom Line
WiFi networks work most of the time; however, after rebooting your router for the fifth consecutive time you may feel the need for a permanent fix.  By changing your  power settings, and installing the latest updates you will obviate the problem 90% of the time. The other 10% might mean you need to reset the router to its factory defaults or in pretty rare cases buy a new router.
