g440i Posted May 28, 2014 Report Share Posted May 28, 2014 Hi, I'd like to know what exactly is "Optimize disk I/O while CPU is idle" do? I'm using a SSD and I'm afraid it's a scheduled defrag which I don't perfer on a SSD. Thanks! Allieplaums, Codilayeri, StefanKew and 2 others 5 Link to comment Share on other sites More sharing options...
xilolee Posted June 2, 2014 Report Share Posted June 2, 2014 Hi g440i. Where can you see that option? (Because I can't see it) In the latest version of wise registry cleaner 8.12.534, there is optimize disk i/o Subsystem to improve system performance. Link to comment Share on other sites More sharing options...
g440i Posted June 2, 2014 Author Report Share Posted June 2, 2014 Hi g440i. Where can you see that option? (Because I can't see it) In the latest version of wise registry cleaner 8.12.534, there is optimize disk i/o Subsystem to improve system performance. My version is 8.11.533, it's in the system tuneup BTW, what is that optimize disk i/o Subsystem to improve system performance do? Because I'm using SSD, I'm concern on both those optimize disk i/o features. I think it's for HDD and may be harmful to SSD. Link to comment Share on other sites More sharing options...
xilolee Posted June 3, 2014 Report Share Posted June 3, 2014 I think it changes the value of NoLowDiskSpaceChecks from 0 to 1. (in HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer)Check: Description of the Low Disk Space Notification in Windows XPThat should also be valid for newer Windows versions.If you want more certainty, wait for WiseCleanerAdmin's response (or developers'response). Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted June 4, 2014 Report Share Posted June 4, 2014 Yes, xilolee is right. This optimization is safe to SSD. Link to comment Share on other sites More sharing options...
g440i Posted June 4, 2014 Author Report Share Posted June 4, 2014 Yes, xilolee is right. This optimization is safe to SSD. So, all those "optimize" for disk i/o are just disable notification, which is somewhat useless? Link to comment Share on other sites More sharing options...
