Raimison Posted April 29, 2014 Report Share Posted April 29, 2014 Eu usei 2 vezes o programa pra resolver esse problema da imagem..E não deu! Operating system:Windows 7 Professional (32 bit) Service Pack 1 System root: C:\Windows Available physical memory: 2013 MB CPU: Pentium® Dual-Core CPU T4500 @ 2.30GHz Drive Info: C: 146,39 GB D: 151,60 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
xilolee Posted April 29, 2014 Report Share Posted April 29, 2014 translated from portuguese: 2 times I used the program to solve this image problem .. It did not work! What's that wdm progam? Link to comment Share on other sites More sharing options...
Raimison Posted May 2, 2014 Author Report Share Posted May 2, 2014 "WDM" (gerenciador de downloads vencedor) http://www.winnerdownloadmanager.com/ Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted May 6, 2014 Report Share Posted May 6, 2014 Did you have a try to use Wise PC 1stAid to solve your problem? Or, uninstall it, then restart computer, then install it again. Link to comment Share on other sites More sharing options...
