zoeff50 Posted April 17, 2014 Report Share Posted April 17, 2014 hello Wise Support, Using Wise Reg Cleaner 8. Program and backup functions worked ok, but due to a fatel Windows Update, I had to reinstall Windows 8 and all my programs again. Reinstalled the Wise Programs, but the Create System Restore function in Reg Cleaner is not working anymore; backup registry works ok. Any idea what the problem is? Thanks. StefanKew, Shauntest, Lorrineet and 1 other 4 Link to comment Share on other sites More sharing options...
xilolee Posted April 17, 2014 Report Share Posted April 17, 2014 If you create a system restore point through Windows, does it work? Link to comment Share on other sites More sharing options...
zoeff50 Posted April 17, 2014 Author Report Share Posted April 17, 2014 System Restore Point via Windows or 3rd party program Restore Point Creator works ok. On 2nd Win7 x64 laptop System Restore Point via Wise Reg Cleaner works ok. Something to do with Win 8.1 latest update? Same programs are installed on both laptops. Link to comment Share on other sites More sharing options...
xilolee Posted April 20, 2014 Report Share Posted April 20, 2014 I have got Win 8.1 (updated) and Wise reg cleaner 8.03.530, but it works: Anyway, we (Windows users) can't create more than one system restore point in 24 hours. Link to comment Share on other sites More sharing options...
