Task Scheduler Engine stopped working and was closed
"A problem caused the application to stop working correctly. Windows will notify you if a solution is available." Notification appearing repeatedly on a daily basis, but no solution presents itself.
Operating system:Windows Vista Business (32 bit) Service Pack 2
System root: C:\Windows
Available physical memory: 1999 MB
CPU: Intel® Core2 Duo CPU P8400 @ 2.26GHz
C: 149.05 GB
Internet Explorer: 9.0
Link to comment
Hi,
1, restart computer, press F8 to run Safe Mode
    Does this problem appear in Safe Mode?
2, If no, some programs cause this problem.
    open Control Panel-->System and Security-->Administrative Tools-->Task Scheduler, stop all tasks
    then restart computer.
3, If this problem still appear in Safe Mode, some system file may lost or broken
    click Start menu-->type cmd.exe and press Enter-->type sfc /scannow to scan and fix system files.
Link to comment
