Звук
Помогите пожалуйста. Я не могу запустит службу windows audio пиши что ошибка 1059.
Operating system:Windows 7 Home Basic (64 bit)
System root: C:\Windows
Available physical memory: 4857 MB
CPU: AMD A8-4500M APU with Radeon HD Graphics
C: 97,56 GB
D: 368,10 GB
Internet Explorer: 8.0
Link to comment
Translated from russian:
sound
Help please. I can not start the service windows audio write the error 1059.
Check, between your Windows services, if multimedia class scheduler, Windows audio endpoint builder, rpc endpoint mapper, and dcom server process launcher are running.
Link to comment
Is it possible to be simpler?
I hope this will be clearer/simpler
  • Press Windows key on your keyboard (and keep it pressed), then press R key, release the two keys (Windows + R): it will open the run window
  • Inside the run window, type services.msc and press enter: it will open the services window
  • Find dcom server process launcher and check under the status column if it is RUNNING.
  • Find multimedia class scheduler and check under the status column if it is RUNNING.
  • Find rpc endpoint mapper and check under the status column if it is RUNNING.
  • Find Windows audio endpoint builder and check under the status column if it is RUNNING.
  • If one of those services are not running, the Windows audio service will not start (and run). Solution: try to start them.
Link to comment
I have everything working except for those services here
Building tool endpoints Windows Audio
Plug & Play
food
Windows audio
I didn't understand "food".
If "Building tool endpoints Windows Audio" is Windows audio endpoint builder, and it is not started, that's why Windows audio doesn't work/start.
Plug and play service should be automatic and started.
Have you tried to start them? And to change their startup type to automatic?
Link to comment
