wisecleaner_admin Posted March 20, 2014 Report Share Posted March 20, 2014 Many user purchase Wise Care 365 Pro, or get a free key, but they don't know how to enter key to activate Pro version. If you are one of them, follow me! 1) Download and install the latest version of Wise Care 365. (If you have installed Wise Care 365, skip this step) 2) Run Wise Care 365 3) Click “Full version” button on the upper right. 4) Enter your name, email, and your license key (copy & paste) in the form. 5) Click 'Register'to activate the full version. 6) If you still don't clearly, please call our 24x7 line for help. PatrickAlkat, yapedJet, sapedJet and 30 others 33 Link to comment Share on other sites More sharing options...
monirtiti Posted June 14, 2014 Report Share Posted June 14, 2014 Quand j'entre mon courriel sous forme de texte, je reçois toujours que mon adresse email est faux et que le produit ne veut s'activer comme vous constatez dans la photo ci-jointe ( https://imageshack.com/i/mvxr06p ), donc svp comment faire pour activer mon produit ... monirtiti 1 Link to comment Share on other sites More sharing options...
xilolee Posted June 17, 2014 Report Share Posted June 17, 2014 translated from french: When I enter my email in text form, I always get my email address is wrong and that the product does not want to activate as you can see in the attached photo (https://imageshack.com/i/mvxr06p ), so please how do I activate my product ... If I see correctly your screenshot, you can't insert @ between your username and gmail.com. Is this correct? Write your full email in notepad, as an example, and later copy/paste it in that wise care 365 form. It is an already reported problem (I hope developers will fix it soon). Link to comment Share on other sites More sharing options...
babu92 Posted June 18, 2014 Report Share Posted June 18, 2014 Hi in new version there is no language-russian will you add it in new version? Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted June 19, 2014 Author Report Share Posted June 19, 2014 @babu92, Yes. We will add Russian language in next updates. We will gradually add more language packs. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted June 19, 2014 Author Report Share Posted June 19, 2014 @monirtiti, The latest version 3.12 has fixed this issues. It supports context menu, like copy, paste, delete... Link to comment Share on other sites More sharing options...
Rajat16 Posted May 14, 2020 Report Share Posted May 14, 2020 One of the best software to use. Link to comment Share on other sites More sharing options...
ankit213506 Posted July 1, 2020 Report Share Posted July 1, 2020 Go to Google & search for it. Even you can get an answer from the team. Link to comment Share on other sites More sharing options...
Megs Posted February 18, 2021 Report Share Posted February 18, 2021 At times, user gets a pirated key, how to ensure this doesn't happen. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted February 19, 2021 Author Report Share Posted February 19, 2021 @Megs Hello, Wise Care 365 CAN NOT be activated with a pirated key. If you try to register with a pirated key, you will receive the error message "Cannot find your registration information" or "Invalid license key". If you activate Wise Care 365 by cracking, you will receive a warning message every time you open Wise Care 365. "You are possibly a victim of pirated license key...". Please CLICK HERE to fix this issue. Link to comment Share on other sites More sharing options...
prodigalson1225 Posted November 3, 2021 Report Share Posted November 3, 2021 I am beginning to think I have been victim to a scam. Why make it so difficult to register and activate? I purchased using PayPal but have not received a key. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted November 5, 2021 Author Report Share Posted November 5, 2021 @prodigalson1225 Sorry about that. The license key was sent to your mailbox, please check the inbox and the spam folder. For more hel, please feel free to contact [email protected] Link to comment Share on other sites More sharing options...
samiswise Posted December 17, 2021 Report Share Posted December 17, 2021 Hi, i have a 3 PC license. If i use the key on the 4th PC, will it accept and automatically kick the 1st PC with the license out? I won't overuse my license, just that i reinstall windows. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted December 28, 2021 Author Report Share Posted December 28, 2021 @samiswise Sorry for the late reply. If you reinstall the OS, please enter the license key to register. If you want to use the key in a new computer, please contact us to reset it. Link to comment Share on other sites More sharing options...
caran Posted April 10, 2022 Report Share Posted April 10, 2022 Thank you for good software! Link to comment Share on other sites More sharing options...
jamessteven Posted August 15, 2022 Report Share Posted August 15, 2022 Thanks for detail and website new layout is awesome. Link to comment Share on other sites More sharing options...
