Bootup Booster
  • Please log in to reply
7 replies to this topic
#1 mononcleken
mononcleken
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 02 June 2013 - 04:01 AM
I try a couple times to run the bootup booster but each time i reboot my PC it says wise care 365 is not set to run on start up. But everything is check in the menu/settings/general/system.
  • BudemixPoemn likes this
#2 Config
Config
    Advanced Member
  • Moderators
  • 465 posts
Posted 09 June 2013 - 08:12 AM
Hi Mononcleken,
We suggest that  you create a task in the Task Scheduler.
#3 J.P
J.P
    Advanced Member
  • Moderators
  • 131 posts
  • LocationDenmark
Posted 04 July 2013 - 07:33 PM
Hi Wise :)
I had not really thought about it before now, but I get no weather information...
Could it be that I live in the 'wrong' time zone or is there a solution?
A shot in the dark: Could you put a time zone selection into the product?
J.P
Best regards
JP
#4 Lode
Lode
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 04 July 2013 - 10:04 PM
Hi!  :)
I've enjoyed utilizing Wise Care 365 Free for quite some time, and am very pleased with it.
I have some questions about Bootup Booster:
I assume it boosts up bootup speed, yet I'm not sure it does that on my notebook. Sometime ago the fastest time it gave in the pupup was around 40 seconds, but that was only for a short time. It showed a passenger jet. But then it became a car, then a bike, and now it's showing a snail and 144 seconds:
As is visible the bootup is not yet complete, as the red Avira Icon still shows a white closed umbrella, which opens later, and there is still a blue circle on the Network "stairs" next to the speaker icon.
So actual bootup time is a few minutes longer than indicated by the popup.
Also, it says "Can't access weather information", and from the above posts I now understand it's possible to have something about the weather shown. But I don't really need that.
I've already checked my Startup Manager, and only have the 2 webcam items turned off (at the bottom of second screen shot)
Again, I'm grateful to be able to utilize the various functions, and all for free! B)  (I recommended it to a friend, and she got the paid version.) Yet I wouldn't mind understanding a bit more about it. Otherwise -if not- it's perfectly fine as well as it is.  :D
#5 rogerwies1
rogerwies1
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 15 September 2013 - 06:27 PM
my setting say it is enabled at start up but snail says it is not
#6 ronc2vn
ronc2vn
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 27 December 2013 - 12:56 PM
Recently my bootup booster stopped displaying weather information -- this after I had begun to rely on it for my first look at weather for the morning. Now it simply displays a "can't access weather information" message. I have done nothing (that I'm aware of) to cause this change, in fact I can find no way to configure or alter the bootup booster in any way, so my question is twofold:
Why did it stop displaying weather,
and
How do I get weather information back?
#7 xilolee
xilolee
    Advanced Member
  • Moderators
  • 4,345 posts
Posted 28 December 2013 - 06:43 PM
Hi ronc2vn! :)
Which weather program/application are you referring to?
Which O.S. are you using?
32 or 64 bit?
Which firewall are you using?
Which antivirus are you using?
Which version of wise care 365 are you using? The latest? Free or Pro?
#8 WiseCleaner
WiseCleaner
    Advanced Member
  • Moderators
  • 1,093 posts
Posted 02 January 2014 - 09:48 AM
and
Don't worry about it. We are trying to solve this problem.
Please try the latest version of wise care 365 v2.93
Click Here to download it.
We want to put smile on your face.    :)
News: Halloween 2017
Best Regards,
WiseCleaner.com
Follow us on:
