Billy Posted February 25, 2014 Report Share Posted February 25, 2014 I system restored my computer and when I went to check my hidden files, I noticed that the password to access them had changed. For the life of me I could not guess it which was kinda frustrating seeing as I had hidden around 80 GBs of stuff. I was resolved not to pay the $10 password reset fee and I had given up when by chance I discovered a way to not only locate my files, but retrieve them WITHOUT the password. I figured it was a glitch and so I hid a few more files (less important ones) just to test out my method and it worked. It has worked without fail. Who do I notify about this? pokras, UCanFixIt and AppeptGause 3 Link to comment Share on other sites More sharing options...
UCanFixIt Posted February 25, 2014 Report Share Posted February 25, 2014 Hi Billy, You've taken the first notification step by posting here. Next, I would expect someone from Wise to establish communications with you (from this thread) and provide you with a method to deliver the specific details related to the bug you found. Also, I thank you for not posting any specifics here. I am not a Wise employee but I expect someone from Wise to respond, given that you may have found a workaround to get at those hidden file. Thanks for your concern, UCanFixit Link to comment Share on other sites More sharing options...
davidwn Posted June 19, 2014 Report Share Posted June 19, 2014 When I read this post it aroused my curiosity - could I find where the passwords were stored and if so would they be encrypted - the other motive was concern about the security of the program and of course how safe were my hidden files ! Before I continue let me say I have no knowledge of programming or reverse engineering and do not consider myself to be a 'hacker' - but when I use a program which involves protecting personal data I check it out very carefully as most reasonably streetwise people would ! The first password to open the program and show a list of hidden files was easy to find - it was stored as a cypher (which I broke easily) and was very simple to reset. The secondary passwords - to lock down individual files took a little more work but was done using another Wisecare product and were stored as plain-text. My humble opinions (and respectful suggestions); 1. This is a very nice and polished folder hiding program - it hides folders using a method better than any other program I have tested and is perfect to keep files away from casual nosey parkers. 2. If you are hiding a file which is VERY sensitive - then encrypt it first using a password you can NEVER forget. 3. Keep an encrypted backup of hidden files (maybe on a USB stick) using a password you can NEVER forget. (losing family photos is devastating for most people!). 4. I understand Wisecares need to generate income and like to sell the $10 service package - but please don't provide a password retrieval service - when it comes to security there should be no 'back doors' - Hidden files should be automatically encrypted using something like AES 256 and the passwords should not be stored anywhere or be retrievable - Everybody in this day and age knows DON'T FORGET THE PASSWORD - and if you do - don't blame the software of the company that provided it. (#2 above of course would not be needed if the 'back door' was bricked up and encryption implemented. Link to comment Share on other sites More sharing options...
donut Posted September 17, 2014 Report Share Posted September 17, 2014 I system restored my computer and when I went to check my hidden files, I noticed that the password to access them had changed. For the life of me I could not guess it which was kinda frustrating seeing as I had hidden around 80 GBs of stuff. I was resolved not to pay the $10 password reset fee and I had given up when by chance I discovered a way to not only locate my files, but retrieve them WITHOUT the password. I figured it was a glitch and so I hid a few more files (less important ones) just to test out my method and it worked. It has worked without fail. Who do I notify about this? Hi there, We'd like to help you with the issue. Since you did a system restore , please reinstall Wise Folder Hider to check out if it can help you out. Thanks! Link to comment Share on other sites More sharing options...
