raman Posted February 17, 2014 Report Share Posted February 17, 2014 i updated windows 8.1 but cannot access windows store applications installed. it gives only blue screen when clicked. Operating system:Windows 8.1 Pro (32 bit) System root: C:\WINDOWS Available physical memory: 2934 MB CPU: Intel® Core i3 CPU M 370 @ 2.40GHz Drive Info: C: 79.98 GB E: 218.01 GB Internet Explorer: 11.0 Link to comment Share on other sites More sharing options...
UCanFixIt Posted February 17, 2014 Report Share Posted February 17, 2014 Is this issue in addition to your other issue here? http://forum.wisecleaner.com/index.php?/topic/4872-ie/&do=findComment&comment=10411 Sounds like you have multiple issues after upgrading so here's my recommendation at this point: How to Do a Repair Install of Windows 8.1 without Losing AnythingGood luck,UCanFixit Link to comment Share on other sites More sharing options...
xilolee Posted February 17, 2014 Report Share Posted February 17, 2014 From Update to Windows 8.1: FAQ (click) Will I be able to keep my files, settings, and apps?If you start your PC from installation media that you created when you downloaded the ISO, such as a DVD or USB flash drive, you won't be able to keep your apps, Windows settings, or personal files when you install Windows 8.1.This table shows what you can keep when you update, depending on the version of Windows you currently have running on your PC. To verify which version of Windows you have now, see Which Windows operating system am I running?If you're running You can keepWindows 8 Windows settings, personal files, and most apps Where most apps isn't equal to ALL apps. If Windows store doesn't work, you can try these commands (from an elevated command prompt): powershell -ExecutionPolicy Unrestricted Add-AppxPackage -DisableDevelopmentMode -Register $Env:SystemRoot\WinStore\AppxManifest.xml start "" "ms-windows-store:" Keep us informed. Link to comment Share on other sites More sharing options...
