UCanFixIt Posted February 13, 2014 Report Share Posted February 13, 2014 Hello all, This is a fairly well-known option but I thought I would post the "how-to" just in case you didn't know about it. This simple procedure will create a Gode Mode Icon on your desktop that allows you to browse almost every available option on your computer. How to activate: 1. Create a new folder on your desktop - see image1 2. Right click and rename the folder exactly as shown below (you can cut and paste the correct rename from below) - see image2 GodMode.{ED7BA470-8E54-465E-825C-99712043E01C} 3. Once renamed, that folder icon will "immediately" change to a God Mode icon - see image3 4. Click the new icon and browse all of your available options that are now categorized for easy viewing - see image4 Comment: This option essentially provides an alternative way to view and access virtually every option available in Control Panel without the need for continual navigation. Hope you like it! UCanFixit David Bailey, xilolee and amysanaghan 3 Link to comment Share on other sites More sharing options...
