carolgird Posted January 15, 2014 Report Share Posted January 15, 2014 I get this error message "An error occurred in the database(PC-FAX phonebook and Transmission List data) when my pc boots up each time..How do I fix it. Also when I click on the start button and want to search my programs it is blank and I can't do a search. How do I fix that. Operating system:Windows 7 Home Premium (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 5611 MB CPU: AMD A8-3500M APU with Radeon HD Graphics Drive Info: C: 581.37 GB D: 14.50 GB F: 0.09 GB Internet Explorer: 11.0 Link to comment Share on other sites More sharing options...
xilolee Posted January 16, 2014 Report Share Posted January 16, 2014 Hi carolgird! For the fax problem, use a restore point before the problem occurred. Did it occurr after you have installed the wrong version of directx? For the search problem, try: 1) Go to Control Panel, Appearance and Personalization, Folder Options, search tab, restore defaults, ok 2) Control panel, Check the Windows Experience Index, Adjust Indexing Options, modify, under included locations you should see start menu and users (appdata folders excluded) 3) click advanced, click rebuild, click ok Keep us informed. Link to comment Share on other sites More sharing options...
