No Muestra El Icono
  • Please log in to reply
5 replies to this topic
#1 Darlin
Darlin
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 11 January 2014 - 11:31 PM
No Muestra el icono y estoy muy asustado puede ser un problema muy grande
System root: C:\WINDOWS
Available physical memory: 446 MB
CPU: Intel® Pentium® 4 CPU 3.00GHz
C: 18,55 GB
E: 18,68 GB
Internet Explorer: 8.0
  • Darlin likes this
#2 xilolee
xilolee
    Advanced Member
  • Moderators
  • 4,345 posts
Posted 12 January 2014 - 12:49 PM
Hi darlin! :)
Have you tried the proposed solution inside wise pc 1st aid?
#3 Darlin
Darlin
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 12 January 2014 - 09:05 PM
yeah lo eh intentado y nada queda igual.
#4 xilolee
xilolee
    Advanced Member
  • Moderators
  • 4,345 posts
Posted 12 January 2014 - 10:12 PM
Do you miss only chrome icon?
#5 Darlin
Darlin
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 13 January 2014 - 06:40 PM
sii lo extraño pero que se quede asii el navegador funciona correctamente thanks for the help
#6 xilolee
xilolee
    Advanced Member
  • Moderators
  • 4,345 posts
Posted 13 January 2014 - 08:17 PM
Right-click Google chrome (link), properties, click shortcut tab, click change icon... button, if you can see Google chrome icons, choose the one that you prefer (if there are more than one) and click ok.
If you can't see Google chrome icons, check the path that is written in the editbox look for icons in this file:, it should show the full path of Google chrome, that usually is C:\Program Files (x86)\Google\Chrome\Application\chrome.exe.
If it is not shown, you can click browse button, navigate the folders, find chrome.exe, click ok, you should see chrome icons and you can choose your preferred one, if there are more than one.
