furrypaws Posted August 1, 2013 Report Share Posted August 1, 2013 saying one or more of my activex controls is not working or disabled Link to comment Share on other sites More sharing options...
WiseCleaner Posted August 1, 2013 Report Share Posted August 1, 2013 Try to follow these steps: 1.Click Start, click Run, type regedit, and then click OK. 2.Expand the following registry subkey: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\0 3.In the right pane, right-click 1200, and then click Modify. 4.In the Value data box, type either 1 or 0 to overwrite the existing value of 3. Then, click OK. Note If you type 1 in the Value data box, you will receive the following prompt when you start Microsoft Project: Do you want to allow software such as ActiveX controls and plug-ins to run?Additionally, you will receive this prompt at other times when you use Microsoft Project. If you do not want to receive this prompt, type 0 in the Value data box. The values 0, 1, and 3 are associated with the following behavior: ·0 = Enabled, or the action is permitted ·1 = Prompt ·3 = Disabled, or the action is not permitted 5.Quit Registry Editor. IF this does not works try to check the Internet Options.. Try to reset the Internet Explorer. 1. Click on Start & run. 2. Type inetcpl.cpl & click ok 3. Click on Advanced Tab & click on Reset (Make sure to put the check mark on the delete the personal setting for IE) then again reset. 4. Click close. Link to comment Share on other sites More sharing options...
