marita123 Posted January 2, 2014 Report Share Posted January 2, 2014 MY EXTERNAL HARDISK ( WD) WHICH IS CONECTED TO YHE USB PORT WILL NOT SHOW UP IN MY COMPUTER AND IT WILL NOT START Operating system:Windows 7 Home Premium (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 4000 MB CPU: Intel® Core i3-2350M CPU @ 2.30GHz Drive Info: C: 119,24 GB D: 153,85 GB Internet Explorer: 11.0 Link to comment Share on other sites More sharing options...
WiseCleaner Posted January 3, 2014 Report Share Posted January 3, 2014 Hi, Do you try to plug-in your external hard disk in another computer? Or, try to use another USB port of your computer, rear port is better. Link to comment Share on other sites More sharing options...
my2cents Posted January 3, 2014 Report Share Posted January 3, 2014 MY EXTERNAL HARDISK ( WD) WHICH IS CONECTED TO YHE USB PORT WILL NOT SHOW UP IN MY COMPUTER AND IT WILL NOT START Your issue is unclear based on the information provided. What does "will not start" mean? Does it actually run? What is the make/model number of the external drive? Is it a WD Passport or similar make that has special firmware and security software installed? FYI, an external drive must have an active volume to show up in my computer. If yours does not, you can create a simple volume in computer management. Link to comment Share on other sites More sharing options...
marita123 Posted January 19, 2014 Author Report Share Posted January 19, 2014 I have a WD external hardisk which I plug into my USB port, this has been working very well, but today the USB port do not work, what can I do ? Operating system:Windows 7 Home Premium (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 4000 MB CPU: Intel® Core i3-2350M CPU @ 2.30GHz Drive Info: C: 119,24 GB D: 153,85 GB Internet Explorer: 11.0 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted January 21, 2014 Report Share Posted January 21, 2014 Hi, please try other USB ports, rear port is better. If it cannot work, try to use other USB device to check whether your USB ports are working well. Maybe reboot system can solve it. Link to comment Share on other sites More sharing options...
