davel Posted December 29, 2013 Report Share Posted December 29, 2013 Cannot back-up files onto Seagate external drive, error shown is "Cannot make shadow copy fault 0x8004230F Operating system:Windows Vista Home Basic (32 bit) Service Pack 2 System root: C:\Windows Available physical memory: 2037 MB CPU: Intel® Celeron® M CPU 430 @ 1.73GHz Drive Info: C: 31.89 GB D: 465.76 GB Internet Explorer: 9.0 Link to comment Share on other sites More sharing options...
xilolee Posted December 29, 2013 Report Share Posted December 29, 2013 Hi davel! 1) Open an elevated command prompt, type powershell, press enter2) Copy/paste the following command and press enter get-service -include "dcomlaunch", "mmcss", "plugplay", "rpcss", "vss" | select-object displayname, name, status | sort-object name | format-table -auto I obtain this DisplayName Name Status ----------- ---- ------ DCOM Server Process Launcher DcomLaunch Running Multimedia Class Scheduler MMCSS Running Plug and Play PlugPlay Running Remote Procedure Call (RPC) RpcSs Running Volume Shadow Copy VSS Stopped You should have the same results.If this is not the case:3) press Windows key + R key on your keyboard (Windows + R), it opens the run window, type services.msc, press enter, find those services and change their properties: startup type = automatic(vss should be manual, but you can try to change it to automatic)4) restart the pc and re-try your backup procedureLooking forward for your kind feedback. Link to comment Share on other sites More sharing options...
