Tracey Posted December 8, 2013 Report Share Posted December 8, 2013 When the computer comes on a box pops up about RunDLL missing and can't open? Operating system:Windows 7 Home Premium (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 4008 MB CPU: Intel® Pentium® CPU B940 @ 2.00GHz Drive Info: C: 297.99 GB Internet Explorer: 11.0 Link to comment Share on other sites More sharing options...
xilolee Posted December 8, 2013 Report Share Posted December 8, 2013 Hi tracey! Does your PC start with that message and you can work on it OR does your PC start with that message and you CAN'T work on it? I have got one rundll32.exe inside c:\windows\system32 and I have a copy of it inside C:\Windows\WinSxS\amd64_microsoft-windows-rundll32_random-numbers (I think it is the same, but I only checked the size). I have got another one inside c:\windows\syswow64 and I have a copy of it inside C:\Windows\WinSxS\x86_microsoft-windows-rundll32_random-numbers (I think it is the same, but I only checked the size). If you don't have copies inside those folders, you can copy those files from another pc with your same OS. How can you check if you have those copies inside your pc? Open a command prompt and type: dir c:\windows\rundll32.exe /a /b /s And you will have a list of the folders/directories where you can find rundll32.exe, any version it is... If this doesn't work, too, you can try to launch sfc /scannow from an elevated command prompt (command prompt started as an administrator). Looking forward for your kind feedback! Link to comment Share on other sites More sharing options...
Tracey Posted December 9, 2013 Author Report Share Posted December 9, 2013 This is what pops up: RunDLL There was a problem starting C:\Users\Traey\AppData\Conduit\BackgroundContainer\BackgroundContainer.dll The specified module could not be found Link to comment Share on other sites More sharing options...
xilolee Posted December 9, 2013 Report Share Posted December 9, 2013 Download adwcleaner portable (click) and run it. Link to comment Share on other sites More sharing options...
Tracey Posted December 9, 2013 Author Report Share Posted December 9, 2013 Didn't know where to put this but your 2nd answer to my problem WORKED!!! So Happy!!! Thankyou very much! Tracey Operating system:Windows 7 Home Premium (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 4008 MB CPU: Intel® Pentium® CPU B940 @ 2.00GHz Drive Info: C: 297.99 GB Internet Explorer: 11.0 Link to comment Share on other sites More sharing options...
xilolee Posted December 9, 2013 Report Share Posted December 9, 2013 Link to comment Share on other sites More sharing options...
