Edinaldo Posted November 25, 2013 Report Share Posted November 25, 2013 janela incômoda que aparece constantemente na tela do computador. Não afeta nenhum programa. Mas preciso ficar clicando toda hora no x para fechá-la. Operating system:Windows 7 Ultimate (64 bit) System root: C:\Windows Available physical memory: 3939 MB CPU: Intel® Core i5-2310 CPU @ 2.90GHz Drive Info: C: 931,41 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
Config Posted November 25, 2013 Report Share Posted November 25, 2013 In most case, registry problem is the reason to blame for this error. Registry is the most critical component of Windows that stores every data and configuration of your computer, every hardware/software needs to connect to registry to function properly. However, the everyday regular use of computer will keep creating wasted/invalid/obsolete that could dilate the registry and cause registry malfunction eventually, this could lead to system slowness and various system error including the communicator.exe error. Now you've known the truth, you can try to fix the registry error by cleaning up those junk entries and repairing those corrupted registries. There is another fact, however, among numerous computer users, most of them are just general computer users who lack of professional knowledge about computer and the system structure, so it is nearly impossible for many of computer users to manually find out and delete all these wasted/invalid/obsolete registries from their computer system, they will be very easy to result in the incomplete or incorrect registry fix, which will not only cannot fulfill the fixing job, but also create other further and serious troubles for the computer system. Therefore, it is recommended to use registry cleaner to help you accomplish this task: http://www.wisecleaner.com/wiseregistrycleanerfree.html Link to comment Share on other sites More sharing options...
