Edmar Posted November 24, 2013 Report Share Posted November 24, 2013 não abre Operating system:Windows Vista Starter (32 bit) Service Pack 1 System root: C:\Windows Available physical memory: 1789 MB CPU: AMD Athlon Processor TF-20 Drive Info: C: 219,88 GB Internet Explorer: 7.0 Link to comment Share on other sites More sharing options...
Config Posted November 25, 2013 Report Share Posted November 25, 2013 Hi First of all, we strongly suggest that you update your IE to higher version to avoid further problems. Then, some suggestion for your status quo: Go to menu bar and select Tools > Internet Options Open the General tab and under Tabs, click Settings In the window that opens, select Always open pop-ups in a new tab Click OK to save the changes Link to comment Share on other sites More sharing options...
