ben Posted July 30, 2013 Report Share Posted July 30, 2013 can not open msconfig Link to comment Share on other sites More sharing options...
april Posted July 31, 2013 Report Share Posted July 31, 2013 What is your configuration of your PC? For Windows XP First of all, you need to make sure that the MSCONFIG program is still present on your drive. Surprisingly, the odd thing about MSConfig.exe is it’s not located in either of the 2 most obvious directories of C:\Windows or C:\Windows\System32 on Windows XP, which is where the other system utilities are found. In Windows XP MSConfig.exe is stored in the following location: C:\Windows\PCHealth\HelpCtr\Binaries\MSConfig.exe Go to C:\Windows\PCHealth\HelpCtr\Binaries\ and check if the MSConfig.exe file is there or not. If it’s not there, you can copy it from another computer to the Binaries folder or if you only have a Windows XP CD, open a command prompt window, insert your XP CD into the drive and enter the following command: (assuming D is your CD drive and C is where your Windows is installed) That should restore MSConfig.exe to your Windows install. If you do not have access to another computer or the XP installation CD, you can download MSConfig.exe from below. EXPAND -R D:\I386\MSCONFIG.EX_ C:\WINDOWS\PCHEALTH\HELPCTR\BINARIES Download MsConfig.exe for XP If the executable is already there and you still can’t launch MSCONFIG from the Run command, then the reference to the path within the registry may be wrong. Check this location in the registry: In the right pane, next to Default, it should show: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\MSCONFIG.EXE C:\WINDOWS\PCHealth\HelpCtr\Binaries\MSConfig.exe If the the path is not correct, simply change it to what is shown above. If you are not familiar in editing the Windows registry, you can just download and run this registry fix file. Download MsConfig Registry Fix Once you have both MSConfig.exe file in your computer and the registry path is set correctly, you shouldn’t have problems running msconfig command from Run. For Windows Vista and 7 In Windows Vista and 7 MSConfig.exe is located in the more common system location you might be expecting: If you can’t find it in the System32 folder, a search in the C:\Windows\WinSXS folder should provide a backup MSConfig.exe which you can copy back over to the System32 folder. If it’s not there either, you will either have to extract it from a Windows install DVD, or you can download the MSConfig.exe file for Windows Vista or 7 from the links below. C:\Windows\System32\MSConfig.exe Download MsConfig for Windows Vista 32-bit | for Windows Vista 64-bit Download MsConfig for Windows 7 32-bit | for Windows 7 64-bit If you want to get the file from your Windows install DVD, using an archiver such as 7-Zip, go to the Sources folder on the disc and open the Install.wim file. Inside are some numbered folders, simply go into any one of them and navigate to Windows\System32 and extract the MSConfig.exe to your System32 folder. If you have a recovery image or partition, there should also be a wim file which likely holds a copy of the file. As MSConfig.exe in Vista and 7 is already located in the default system path, there isn’t a possible bad entry for it in the registry like there is in XP. Link to comment Share on other sites More sharing options...
