Wise Folder Hider - Unhide problem
wise folder hider
  • Please log in to reply
32 replies to this topic
#21 death drive
death drive
    Newbie
  • Members
  • Pip
  • 3 posts
Posted 07 May 2014 - 02:22 PM
how to add pictures in it?
  • AppeptGause, TimothySl and IrvingFies like this
#22 xilolee
xilolee
    Advanced Member
  • Moderators
  • 4,346 posts
Posted 07 May 2014 - 03:07 PM
How to make screenshots (aka snapshots) and post them here in this forum, either through the forum itself or through Wise PC 1st Aid
#23 saurabh28k
saurabh28k
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 10 May 2014 - 02:06 PM
am gettting error as following
The following folder/file can't be unhidden.
*When I try to "unhide" it, it literally shows this message:
The following folder/file can't be unhidden: Pictures Error Message: Access is denied.
Can I system restore, to get all the things I had before downloading your software, then undo system restore to get back the documents I made for work after downloading your software, PLEASURE TELL ME MY PICTURES, VIDEOS, AND DOCUMENTS aren't lost forever, there has to be some way to restore what I had before downloading your software, and after I downloaded it.
i have also tried wise cleaner..it shows my files but can not restore it..after i press restore..it just gives folders with
PLEASEL HELP!!!i am crying
basic description of your system-windows xp
Specific error codes and/or warnings received-these files can not be unhidden and then access is denied
Any software or hardware that you recently installed or removed-none
Any recent changes that were made to the system-none
The amount of time that that you have experienced the problem-24 hours
The things that you have already tried to troubleshoot the problem-all you have mentioned in discussipon
#24 namanlove90
namanlove90
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 26 May 2014 - 04:01 PM
Hi, Don't worry if you have hidden your IMPORTANT DATA,  that you want to recover  at any cost, so first of all you don't have to pay a single penny from your pocket.
Now if you have installed new OS , then still you can get your data. Follow the steps below exactly and carefully :
1.) Download WinRar (which is free to download and use)
2.) Install WinRar in Your system.
3.) After successfully installing winrar, Open Winrar and follow these sub steps :
     a.) open WinRar
     b.) Go to "Command" Tab
     c.) Under the command tab list choose "view file"
     d.) choose the drive to view files ( hidden files)
4.) Now you will see a folder name in dotted like this --> "...." . open this folder
5.) now follow this path and keep open the folders to reach to your Data Files "..../00000/..../hidefolder/hide/"
6.) Now you have reached to your data files path and select your files or folder whatever you had hidden by wise folder hider, select your files or press ctrl+a to select all files
7.) now right click on selected files and choose "Add files to archive"
8.) a window will open, you dont have to change the settings, leave it as it is, browse to the folder where you want to extract your locked data and save it by any name
Note: it will get saved in rar extension file format, later you can access your files using winrar to extract your rar files
9.) The End, Hi5 :)  you have collected your locked data.
 email me if you want more help shinypearl42@gmail.com with the subject "HELP".
Thank You Guys I hope You would like my trick.
#25 Raviraj
Raviraj
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 06 June 2014 - 09:26 AM
Please find a PC which has the same system with your previous windows , install a Wise Folder Hider, and follow the instruction below to retrieve your folders.
Please follow the instructions below to recover your files.
1. Unzip and install the file downloaded from the link below.
http://www.wiseclean...m/tools/WDR.zip
2. Open the main surface of the tool, choose the drive you used to place the files hidden. Then click "Search".
3. Find a folder named "...." (yes! just four dots!) in the left column. Then click the arrows below until you find the folder named "hide".
4. Click on the folder named "hide", a list of files will show up in the right.
5. Select the files you want to retrieve, and click "Restore" at the right bottom corner.
6. In the incoming pop-up, save the files to a different drive (important!).
7. Open the specific folder in the different drive you chose in 6, voila!
Thanks.
I tried this. -_-
It restored the folder to the other drive BUT the folders were empty.
I could still see the files hidden inside the folders in wise data recovery window.
Then I tried restoring single file on other drive but that file just DID NOT get restored.
This is really irritating.
I am at my wit's end :( . Some of the hidden files in other drives got overwritten.  :angry:
Please help!
#26 wisecleaner_admin
wisecleaner_admin
    Administrator
  • Administrators
  • 2,233 posts
Posted 13 June 2014 - 10:30 AM
@Raviraj,
This tool WDR.zip only recover files, not folder.
Please try to recover files again!
Wrong operation:
Correct operation:
New product: Wise Anti Malware
Keep your PC in safe all the time!
Best Regards,
WiseCleaner.com
Follow us on:
#27 ajayjindal
ajayjindal
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 02 October 2014 - 10:00 AM
i am also facing problems with WHF....
help me..
sir,, using this software i hide my personal data aroung 380gb in portable hard drive ... suddenly before two days when i open dis software for doing some changes ,can't find my data.....
plizz help mee.......!!
can i recover that one??
#28 wisecleaner_admin
wisecleaner_admin
    Administrator
  • Administrators
  • 2,233 posts
Posted 15 October 2014 - 07:39 AM
@ajayjindal,
You can refer this topic and try to recover the data.
http://forum.wisecle...-the-wfh-files/
Best Regards,
WiseCleaner.com
Follow us on:
#29 nikhil
nikhil
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 29 June 2016 - 06:01 PM
hello sir
soory for my bad english plz understand
  i cant unhide my folder n files its important to mi .
 when i open hide folder it shows an error as follow
the followimg folder/file can't be unhidden  plz help mi its to important for mi
thank you
#30 wisecleaner_admin
wisecleaner_admin
    Administrator
  • Administrators
  • 2,233 posts
Posted 30 June 2016 - 06:19 AM
Hey nikhil,
The F drive is a local disk, or external disk? when you hide and unhide the file is in the same computer or different computer?
Best Regards,
WiseCleaner.com
Follow us on:
#31 ruwan
ruwan
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 04 July 2016 - 10:41 AM
Hi,
I am using wise folder hider more than five years now. it was best software for me to folder hide. but, today i try to unhide my folders. there is no folder for unhide. now i lost some important  document. plz help me. give me a solution.
#32 Abhinav7
Abhinav7
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 13 October 2017 - 06:39 AM
Hi!
I was opening the software on my device and it prompted for an update and so I initiated the same without unhiding the folders and now I'm unable to open wise folder hider as it is showing some kind of error.I can't do anything with the software , neither can I uninstall to reinstall.
Please suggest any solution ASAP as I urgently need one of the documents from the hidden folders.
I've already mailed to the support team with the error details.
#33 wisecleaner_admin
wisecleaner_admin
    Administrator
  • Administrators
  • 2,233 posts
Posted 13 October 2017 - 07:59 AM
Hi!
Okay, I think  support staff can help you solve it.
Best Regards,
WiseCleaner.com
Follow us on:
Also tagged with one or more of these keywords: wise folder hider
