RayGoetz Posted October 28, 2013 Report Share Posted October 28, 2013 Most of my sound is muffled now after I installed service pac 3 on my xp. what to do.? Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:\WINDOWS Available physical memory: 3039 MB CPU: AMD Athlon II X2 255 Processor Drive Info: C: 95.74 GB D: 94.18 GB F: 76.31 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
Lucy Posted October 28, 2013 Report Share Posted October 28, 2013 Hi, If you have Windows xp and service pack 3 and are experiencing difficulties with having no sound after a fresh installation,try this,it works 1) Open Reg-edit and go to : HKEY_LOCAL_MACHINE\SYSTEM\Current Control Set\Control\Windows\CDS Version 2) Double-click CDS Version and change it to 200, then restart your system. 100 (hex) means its sp1 200 (hex) means its sp2 300 (hex) means its sp3 3) Install kb888111xp2.exe (Microsoft UAA Patch which should be available from your Audio driver folder) 4) Install audio driver 5) Change CSD Version back to 300 (remember this or else you system will think it's still SP2 and many SP2 updates may reemerge in your Windows Update, that's my logical guess anyway :mrgreen: ) 6) Restart your system I hope it will be help you. Link to comment Share on other sites More sharing options...
