Tracy Posted October 21, 2013 Report Share Posted October 21, 2013 Outlook not connecting to Microsoft Exchange. Outlook data not outlook data file Operating system:Windows 8 Pro (64 bit) System root: C:\WINDOWS Available physical memory: 8177 MB CPU: AMD A4-3400 APU with Radeon HD Graphics Drive Info: C: 916.85 GB D: 14.57 GB Internet Explorer: 10.0 Patrickeffob, AnthonyPoelf, helenedi69 and 20 others 23 Link to comment Share on other sites More sharing options...
april Posted October 22, 2013 Report Share Posted October 22, 2013 Hi,try the instruction below. Create a new Outlook profile from the Control Panel, set the new profile as default and then try to open Outlook and check if it works fine. Refer the link mentioned below on how to create a new profile: http://support.microsoft.com/kb/829918 When you create the new profile don't repeat the same error by configuring it to use Microsoft Exchange.If you have manually removed Outlook keys from the registry then all bets are off. You will probably also have to repair Office to put them back. Thanks. Link to comment Share on other sites More sharing options...
