jose Posted September 26, 2013 Report Share Posted September 26, 2013 no me reconoce los driver de usb para pen drivers y me sale un virus recycler Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:\WINDOWS Available physical memory: 1015 MB CPU: Intel® Pentium® 4 CPU 3.00GHz Drive Info: C: 76,68 GB E: 97,66 GB F: 51,39 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
april Posted September 27, 2013 Report Share Posted September 27, 2013 Click Start -> click All Programs -> click Accessories -> right-click Command Prompt, select Run as administrator. If you are prompted for an administrator password or confirmation, type your password or click Continue. At the command prompt, type the following commands (press ENTER after each): SET DEVMGR_SHOW_NONPRESENT_DEVICES=1 devmgmt.msc When in Device Manager, click View then Show hidden devices Expand the category containing your device, and then double-click the name of your device. Click the Driver tab, and then click Uninstall. If there is a Delete the driver software for this device box, check it (make sure you have internet connectivity so that you may reacquire these drivers). Read and Confirm Notification, click OK. Exit Device Manager, and restart your computer. You will be prompted with Found New Hardware. Select Locate and install driver software. Confirm permissions. Windows will now search for your hardware driver and reinstall it. Test the device again Thanks. Link to comment Share on other sites More sharing options...
