elsnyder Posted September 25, 2013 Report Share Posted September 25, 2013 Laptop frequently won't come out of hybernation and I get a hyberfil.sys error. When it boots up after this it will not connect to the network and I have to do a reboot to get everything back and working. Operating system:Windows 7 Home Premium (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 3819 MB CPU: AMD E-450 APU with Radeon HD Graphics Drive Info: C: 450.66 GB Internet Explorer: 10.0 Link to comment Share on other sites More sharing options...
april Posted September 26, 2013 Report Share Posted September 26, 2013 Hi, please try the steps below. Install the BIOS update. Shut down. Remove my ReadyBoost flash memory card Restart Open a "Run as Administrator" Command Prompt Window Type "powercfg -h on" to turn hibernation back on. Shut down (not hibernate!) Thanks Link to comment Share on other sites More sharing options...
april Posted September 26, 2013 Report Share Posted September 26, 2013 Hi, the method above daes not work, please try the instruction below. 1) Disable Hibernation. 2) Delete the hiberfil.sys file.3) Reboot the computer and run 'Disk Cleanup.' 4) Defragment the drive.5) Reboot one more time. 6) Reenable Hibernation. TIPS: How to Enable HibernateNOTE: This step will restore the hiberfil.sys file, and the Allow hybrid sleep and Hibernate after Power Options underSleep. 1. Open a Elevated Command Prompt. 2. In the elevated command prompt, type powercfg -h on and press Enter. (see screenshot below) 3. Close the elevated command prompt. The best way to delete hiberfil.sys or disable hibernate: Go to Start menu, type “cmd” open up command prompt Type “powercfg.exe -h off” [make sure you are an Administrator] ENTER Type “exit” ENTER Thanks. Link to comment Share on other sites More sharing options...
