jomla
Advanced cleaner help
Hi there,
i am realy happy with this nice software,it realy help me fix al my problems and my windows 10
is running very well,but i have little problem.I am running cleaning every day and in advanced cleaner
i get about 300 errors(usualy log files),and this errors is constantly hapening.Is there any way to get rid of them?
Thanks in advance.
Hi,
There are 3 possible reasons:
1, If a file was created by a security software (Avast, Norton, and so on), wisecleaner has not enough permission to remove this file. This file is protected by the security software.
2, A certain application will create the file again after wisecleaner remove it. So, you will see same file after a re-scan, but the file's created date is different.
3, A file will be removed after you restart system.
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
