CptAwesome
Wise Reminder autostart doesn't work
Hello everyone!
I'm using the Wise Reminder for a while now and I'm very satisfied.
There is only one issue that I'm dealing with since the very beginning. It's the autostart option, that doesn't work for me. I tried different versions of wise reminder and windows.
Right now, I'm using Wise Reminder 1.3.1.86 on Windows 10 1803 64bit. "Run on startup" is checked in the options and I can see it in msconfig/taskmanager in the autostart-tab.
Nevertheless I have to start it manually. I experienced the same behavior when I was using Windows 7 64bit.
Anyone having the same issue or do you have any ideas/workarounds?
Cheers!
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
