alexbach
Facing Err Network Changed - Unable to Access Network
Hi Everyone,
I am facing this error - Unable to access the network
The connection to a few websites was interrupted by a change in the network connection.
Furthermore, I got this text -
Here are some suggestions:
Reload this webpage later.
Check your Internet connection. Restart any router, modem, or other network devices you may be using.
Error 21 (net::ERR_NETWORK_CHANGED): A network change was detected.
Can anyone help me? I don't know much about tech.
It seems QIHOO 360 Internet Security now (it was "now" in 2015) "gets a new name – 360 Total Security Essential".
Usually the "internet security" suites are antivirus + firewall.
It seems the firewall used by QIHOO is the one provided by GlassWire.
Therefore: maybe are you using two firewalls? (QIHOO's and microsoft's)
Try to disable temporarily qihoo, just five minutes, and try to navigate (on safe websites, obviously you shouldn't navigate on unsafe ones).
Are you using windows 7? 8? 8.1? 10? x64 or x86?
23 hours ago, Rogerfedrer said:
No no you can restart your system and run your browser this will fix your issue there is no need to reinstall the Chrome Browser.
I tried that already. However, I couldn't fix it through your suggestion.
Hi,
maybe you can try to read the following forum thread to understand your problem better - https://productforums.google.com/forum/#!topic/chrome/Zt_1l4TJFnM
Also, as @xilolee suggested, you should remove or block any ongoing services that might interrupt the process. Now, if you want to try out something for yourself, check this - https://validedge.com/err_network_changed/
Do let me know if this works.
9 hours ago, KaranJohar said:
Hi,
Thank you so much. Will definitely try that.
