Exchange database or EDB file is the information store of Microsoft exchange server. Like any database, the EDB file is also prone to errors arising due to a variety of factors and this can put all the valuable information inside the EDB in jeopardy. Then there are common Exchange errors codes like 528  and JET engine errors that often confuse exchange admins and hinder workflow.
But fear not as gone are the days when an exchange admin faced with such situations had to be content with partial data recovery using native tools as new gen utilities EdbMails EDB to PST Converter can flawlessly recover all the  information from exchange database for you. Most exchange admins know that Outlook .PST is a more manageable file format as its generally used for archiving mailboxes. Thus you can safely recover all your data from exchange database and convert it to PST no matter what state it is in using EdbMails.
EdbMails is designed from ground up to be user-friendly and straightforward. You don’t need any particular technical expertise to be able to use EdbMails for recovery of Exchange database. EdbMails supports Exchange server versions 2016/2013/2010/2007/2003 and Outlook versions 2016/2013/2010/2007. There are also rather extensive filtering options and support for direct migration to Office 365 and Live exchange server in EdbMails
To know more https://www.edbmails.com
Enstella EDB to PST Converter continuously improved functionality of software according to users. This software converts complete EDB files of any size with internal components (task, contacts, calendars, attachments, appointments and embedded images etc.) and save into multiple formats EML, MSG and HTML. EDB to PST Converter use advance algorithm to convert EDB data to different formats in accurate manner. It perfectly works on all MS Exchange versions (32 and 64 Bits).
Read more: http://www.enstella.com/blog/2017/10/14/enstella-exchange-recovery-software/
Exchange Server Recovery is the best and powerful solution to fix all EDB file corruption issues effectively. The software performs accurate recovery of all emails,
attachments, contacts, and other mailbox items from corrupt EDB files in a very short span of time. Read more information and free download click here
http://exchangeserverdatabaserecovery.blogspot.com
SysInspire EDB to PST converter is an absolute solution for Exchange recovery in a secure manner. It has the ability to convert EDB files into many different formats for instance EML, EMLX, MSG, HTML and many more. It can handle any type of corruption issue easily without failure. It can work smoothly on all Windows OS including Windows10, Windows 8, Windows 7 and below versions.
Also read about EDB to PST free here.
