lussinaden
split pst data
Split PST File software is excellent utility which divides large PST file into manageable and smaller PST files as per the specific criterion like size, date, folder and email id, and protects them from any corruption issues because of file size limits.It is fully capable of splitting all MS outlook item such as folders, contacts, calendars, journals, email folders. The software makes you sure that no actual data deleted during the process.This remarkable software help the users to work with many versions of MS Outlook as well as it is compatible with different versions of Windows.
Download link :-
http://www.softakensoftware.com/split-outlook-pst.html
Excellent utility which divides large PST file into manageable and smaller PST files as per the specific criterion like size, date, folder and email id, and protects them from any corruption issues because of file size limits. After splitting a large-sized PST file into smaller pieces, they you can easily accessed with MS Outlook and are completely independent of original PST file.
Check more details, here:- PST Split Software.
PST Splitter software is a very robust & powerful tool that helps you split large Outlook PST files into smaller files as per requirement.
Salient features:
Fastest and Efficient for this process
Splits PST files by Size, Date, Email ID, and Folders
Splits PST files into smaller ones and prevents corruption
Preserves the structure of original PST files after splitting
Supports MS Outlook 2016, 2013, 2010, 2007 & 2003
For more info visit: http://www.completeconverter.com/split-pst/
