kk_in_zdf Posted November 12, 2016 Report Share Posted November 12, 2016 Input to the Login-Window After displaying the login window it would be nice if the program automatically positions the cursor in the password input field. Klaus Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted November 15, 2016 Report Share Posted November 15, 2016 Hey kk_in_zdf, Thanks for your suggestion. Link to comment Share on other sites More sharing options...
kk_in_zdf Posted December 6, 2016 Report Share Posted December 6, 2016 Thank you very much for the realization, that was exactly what I had in mind. Klaus Link to comment Share on other sites More sharing options...
artistasur Posted December 24, 2016 Report Share Posted December 24, 2016 Hello friends. Restoring files o folders from the recycle bin previously deleted from a hidden folder make it visible inside the old directory even with the target folder hidden. Try yourself please!! I run Windows 7 64 bits up to date Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted December 26, 2016 Report Share Posted December 26, 2016 Hey artistasur, Thanks for your feedback. But it is difficult to make the restored file/folder invisible, we don't have a solution yet. My suggestion, when you delete a file/folder (and you are sure you don't use it again), press Shif + Del keys to delete. Or, empty recycle bin Link to comment Share on other sites More sharing options...
maj Posted December 26, 2016 Report Share Posted December 26, 2016 Hey artistasur, If the file was deleted accidentally, then ensure the 'hidden' folder is visible when restoring the file. Then Windows does not create a new un-hidden folder. Link to comment Share on other sites More sharing options...
kk_in_zdf Posted February 17, 2017 Report Share Posted February 17, 2017 Hallo, I'm using Wise Folder Hider 3.39 with Windows 10. Since a long time, on this system I hide/unhide a folder stored on USB-stick.I need the unhidden files on an isolated system running Windows XP (this system is required because of an old application that is not developed further on). Today WFH does not show the hidden of USB-stick folder anymore, neither on Win 10 nor on Win XP. My questions: what did I do wrong and what can I do to see my folder again? When using WDR for the hidden folder it shows me 'lost' (most files), 'very poor' (few files) and 'good' (again few files), but all those 'good' files have zero bytes size. In addition, I should say that neither Win 10 nor Win XP has been updated in the last months. In advance thank you for any help. kk Link to comment Share on other sites More sharing options...
kk_in_zdf Posted February 18, 2017 Report Share Posted February 18, 2017 Hallo, I'm using Wise Folder Hider 3.39 with Windows 10. Since a long time, on this system I hide/unhide a folder stored on USB-stick.I need the unhidden files on an isolated system running Windows XP (this system is required because of an old application that is not developed further on). Today WFH does not show the hidden of USB-stick folder anymore, neither on Win 10 nor on Win XP. My questions: what did I do wrong and what can I do to see my folder again? When using WDR for the hidden folder it shows me 'lost' (most files), 'very poor' (few files) and 'good' (again few files), but all those 'good' files have zero bytes size. In addition, I should say that neither Win 10 nor Win XP has been updated in the last months. In advance thank you for any help. kk Sorry for my yesterday post. Today I can answer my question myself: today everything runs like expected. No idea what was going on yesterday. I had tried it several times without success but today everything is OK. I do not know why it happened yesterday. But I assume that the problems will not appear anymore. Again thank you very much. kk Link to comment Share on other sites More sharing options...
xilolee Posted February 18, 2017 Report Share Posted February 18, 2017 kk_in_zdf: glad you solved it...Sometimes, restarting explorer or windows solves strange problems. Link to comment Share on other sites More sharing options...
xilolee Posted March 6, 2017 Report Share Posted March 6, 2017 Hi. I uninstalled wise folder hider pro 3.36 (?), taken away from a giveaway in June 2016.I used windows control panel, uninstall a program.Problems in the latest version of wise folder hider free:1) "Encrypt file" button isn't translatable2) When changing the language from English to Italian, the two buttons "Hide folder" and "Hide USB drive" don't contain the translations (the text of the second button overlaps the USB icon, like the text of the first one, but in this latter one there are less letters and the icon is still visible).3) In drive D: (where I hid a folder with wise folder hider pro) I can see the hidden folder "....". I don't think I should see it: I didn't see it before.4) When I try to hide the same folder, I get the error message "Can't hide the folder. Error message: Failed to load WiseFs".5) I rebooted, but I got the same problems. Questions:Must I register WiseFs64.sys in c:\windows?Shouldn't wise folder hider installer register WiseFs64.sys by itself?Shouldn't WiseFs64.sys stay in c:\windows\system32 or in c:\windows\syswow64?(The same question for the SYS files of your other programs: WiseRegNotify.sys, WiseUnlock64.sys, WiseTdiFw64.sys... But that's another matter) Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted March 7, 2017 Report Share Posted March 7, 2017 Hey xilolee, Thanks for your feedback. 1 and 2 translation problem, we will improve it. The folder "...." normally it was created by WFH v3, v4 won't use it again. Its properties is Hidden, just change your Folder View settings, then you won't see it again. If you still want to delete it, please email to [email protected], the staff can help you. The error message "Failed to load WiseFs.sys", normally you just need to restart system, then it will be registered automatically. If you have tied it, but it still didn't work, please registered it manually, or uninstall WFH, then reinstall it and reboot. cubTraubokVar, Yourdob, LarryHoirm and 5 others 8 Link to comment Share on other sites More sharing options...
xang Posted April 9, 2017 Report Share Posted April 9, 2017 Hi, I have problems with WHF 4. I used WFH 3 which worked very well on my computer. With WHF4, the folders are not hidden, but only the files in the folders. See the attached file 3 and 4. When I try to open the hidden files with a click in the WHF windows, WHF collapses and just after Directory Opus again. I must do Ctrl+Alt+Delete to stop DOpus and start it again. I tried to repair the files (chkdsk /f) without success. I did not have any problem with WFH 3. If somebody can help me, it would be great. Thank you, Xang Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted April 12, 2017 Report Share Posted April 12, 2017 Hey xand, Please restart system, then try it again. Link to comment Share on other sites More sharing options...
dubbleup99 Posted April 18, 2017 Report Share Posted April 18, 2017 I don't know why, but I keep getting an error after I install Wise Folder Hider. It worked originally then when I did a clean install of Windows 10, I get the same issue. Does anyone have anything? I am running the latest version of the software and Windows 10. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted April 19, 2017 Report Share Posted April 19, 2017 Hey dubbleup99, Thanks for your feedback. The developer team is trying to fix this issue. Now, please try below method 1, Please update Windows system to the latest 10.0.15063 2, Download it from http://downloads.wisecleaner.com/soft/WFHSetup.exe then reinstall it 3, When you finish installation, please restart system before you open it. Link to comment Share on other sites More sharing options...
hungching1982 Posted May 4, 2017 Report Share Posted May 4, 2017 Hi, I have exactly the same problem as dubbleup99 does (#64, above). I have followed the instruction you gave but still keep seeing the error! Please help to solve the problem My system: Windows 10 Home edition (1703)(OS: 15063.250) Link to comment Share on other sites More sharing options...
xilolee Posted May 4, 2017 Report Share Posted May 4, 2017 @hungching1982 I have solved it once reinstalling the program (maybe after a reboot). Did you try it? @WiseCleaner_Admin Instead I have uninstalled version 3 and installed version 4. When I start the program, it asks a password, but it doesn't accept my previous password (that works in version 3). Its length is of three letters (therefore I can't forget it). The main problem about this is I'm not able to verify the (new) translation. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted May 5, 2017 Report Share Posted May 5, 2017 Hey xilolee, Please click Forgot Password button to reset the password. Or, you can download this tool to display the encrypted password and send to me (include you password), I will decrypt it and compare with your password. http://www.wisecleaner.com/soft/GetPassword.exe (please remember to select the option - Find password for WFH Pro) Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted May 5, 2017 Report Share Posted May 5, 2017 Hi, I have exactly the same problem as dubbleup99 does (#64, above). I have followed the instruction you gave but still keep seeing the error! Please help to solve the problem My system: Windows 10 Home edition (1703)(OS: 15063.250) Please re-download the latest WFH, we signed a new digital signature . http://downloads.wisecleaner.com/soft/WFHSetup.exe Link to comment Share on other sites More sharing options...
HiM Posted June 5, 2017 Report Share Posted June 5, 2017 how to delete wisecleaner account forum? @geogeo.gr Thank you very much! Link to comment Share on other sites More sharing options...
geogeo.gr Posted June 20, 2017 Report Share Posted June 20, 2017 Greek translation update to WFH Pro 4.14 WFH_greek.zip Link to comment Share on other sites More sharing options...
crispy Posted June 30, 2017 Report Share Posted June 30, 2017 Would it be possible to get the changelog updated please? http://www.wisecleaner.com/blog_sort_4.html This is still showing version 4.11 from February. There have been many changes since then, some of them undesirable to me. Somewhere since that version, the ability to hide individual folders and files on a USB was disabled. After that update you could only hide the whole drive, but not any files/folders on it. I'm waiting to see if one day that update will be reversed so that I can start using the new WFH again. But people also should be able to see that sort of change before getting latest versions. So please consider maintaining the current changelog so that people can know what they're getting. Thank you. Link to comment Share on other sites More sharing options...
xilolee Posted June 30, 2017 Report Share Posted June 30, 2017 Hi crispy. :-) Are you using the free or the pro version? There are two blogs for the free and for the pro: check the one for the pro. If you think there should be only one, I think the same... ;-) Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted July 5, 2017 Report Share Posted July 5, 2017 Hey, Start from version 4, if you want to view the latest Wise Folder Hider Free changes, please view Wise Folder Hider Pro blog. Link to comment Share on other sites More sharing options...
jugavi Posted October 29, 2017 Report Share Posted October 29, 2017 Hi I see a Security Fault. If I forget the password it is very easy to set up another. If someone else has access to my computer, that person can set another password and I will no longer have access to my folders hidden. Options that could be offered: Delete "I don't remember". Protect "I don't remember" with another password Link to comment Share on other sites More sharing options...
