iamwise Posted May 24, 2015 Report Share Posted May 24, 2015 Wise Folder Hider: If there is anything (file/folder/usb) in the hider, it is still possible that some other user may uninstall or remove the program. Hence, if anything is in the hider, the hider should not be allowed to be un-installed or deleted. If such attempt is made, it should give message that the system cannot remove the program. Or anything that would protect the hidden items. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted May 25, 2015 Report Share Posted May 25, 2015 @iamwise, Don't worry about it. Even you uninstall the program, the hidden file/folder won't be removed. Just need to reinstall wise folder hider, you can see the hidden file/folder. Thank you for your suggestion, we will consider it. Link to comment Share on other sites More sharing options...
DREDDY Posted May 27, 2015 Report Share Posted May 27, 2015 Sorry I speak English with a translator. I need some help. I made the files hidden for the experience as well as their return back to make them visible? Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted May 28, 2015 Report Share Posted May 28, 2015 @DREDDY, Sorry I speak English with a translator. I need some help. I made the files hidden for the experience as well as their return back to make them visible? How did you do? Link to comment Share on other sites More sharing options...
nagovind Posted May 29, 2015 Report Share Posted May 29, 2015 Wise Folder Hider Its a very useful tool. Simple and easy and light weight tool. Please advise how to change the password? Once password is set, i'm unable to change it for a system even after uninstalling and reinstalling it Is there is any possibility to change the password? Please advise. Link to comment Share on other sites More sharing options...
DREDDY Posted May 29, 2015 Report Share Posted May 29, 2015 wisecleaner_admin, I hid the multiple files through the program and now they are visible only through the program. How to do to get back and be seen in Windows Explorer? Help please. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted June 2, 2015 Report Share Posted June 2, 2015 @Dreddy, Please click the little Inverted triangle, click Unhide, then the file/folder will be seen in Windows Explorer. Link to comment Share on other sites More sharing options...
geogeo.gr Posted September 2, 2015 Report Share Posted September 2, 2015 Greek translation update to WFH 3.28 pro WFH_greek.zip Link to comment Share on other sites More sharing options...
WiseCleaner Posted September 11, 2015 Report Share Posted September 11, 2015 Thanks, geogeo.gr! Link to comment Share on other sites More sharing options...
ronny84 Posted November 24, 2015 Report Share Posted November 24, 2015 Hello and thanks for listening to my request. I hide and unhide several folders each day and it seem each time I unhide hidden folder it disappears from the list, so if I want to hide it again I have to browse for folders again!! Could you make it so that once you put a folder on the list it will stay there for me to hide or unhide until I delete it from the list? After using an undeleted folder, it would be nice to just go back into WFH , select the folder or file from the list and hide it again without having to browse for it, just a suggestion, Thank You , johnny1 Hi Johnny1, Actually, I understand your idea. I'm not sure whether most people want this feature. But I will send it to our team, if they think it is a nice idea, they will add it in next version. Thank you very much! I would also like this feature as well. It would be nice to add folders that I want to hide or unhide in the list, but not disappear after I select unhide. Maybe add a delete button next to the hide/unhide dropdown. Also if I unhide a folder and close the application, I would like the folder to stay unhidden, until I open the app again to hide it. Great little app, thanks! ronny84 1 Link to comment Share on other sites More sharing options...
czerwinski76 Posted December 9, 2015 Report Share Posted December 9, 2015 Problem in Wise JetSearch 2.25 Please have a look at my topic here : http://forum.wisecleaner.com/index.php?/topic/11377-wise-jetsearch-dont-find-files-on-the-os-partition/ Link to comment Share on other sites More sharing options...
maj Posted February 22, 2016 Report Share Posted February 22, 2016 If other programs are unable to see my hidden files, what will be the effect during backup - will they not be backed up? A.) with drive/partition backup and B.) selective backup (e.g. My Documents only backup). Thank you. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted February 23, 2016 Report Share Posted February 23, 2016 Hey maj, If you hide a file/folder from My Documents, when you back up My Documents, the hidden file/folder will not be backed up. But, if you back up drive/partition, the hidden file/folder will also be backed up. Link to comment Share on other sites More sharing options...
ADJ Posted February 27, 2016 Report Share Posted February 27, 2016 My file hider wont let me save the file whenever I update it. I must save as desktop... then drag/drop to the correct folder over righting the original. It ask for admin privileges but I am always logged in as the admin. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted March 8, 2016 Report Share Posted March 8, 2016 Hey ADJ, Sorry for the delay. Can you tell me more details? 1, Your OS details. Win 7/8/10? 32bit or 64 bit? 2, UAC settings (user account control settings) 3, What is the correct address of the file that you want to hide? (please copy and paste in here) Thanks. Link to comment Share on other sites More sharing options...
Rod B Posted May 23, 2016 Report Share Posted May 23, 2016 A newbie (to Wise) question: What is "lock?" I'm hoping it has something to do with hiding, When I hide a folder it doesn't hide at all, just camouflages itself" the "hidden" file is a subfolder under a Hide Folder folder under a gibberish named folder. Jameseurox, AnthonyPoelf, orieptate and 12 others 15 Link to comment Share on other sites More sharing options...
WiseCleaner Posted May 25, 2016 Report Share Posted May 25, 2016 Hey Rod B, Thanks. The Lock means whether you have set up second password for this file/folder. What is the perfect hidden tool in your mind? Can't see by any other programs? It is impossible. Wise Folder Hider Free, is a free tool, just provide a simple way to hide file/folder, normally most people can't find the hidden file/folder, even if the Folder Option - Show hidden files, folders, and drives is selected. But, some advanced users can see the hidden file via special tool. We have Wise Folder Hider Pro, it provides higher security, a hidden file even if be seen via a tool, but it can't be opened without your permission.. Link to comment Share on other sites More sharing options...
Rod B Posted May 25, 2016 Report Share Posted May 25, 2016 If there are folders hidden by Wise will defragmentation corrupt them? Thanks. Link to comment Share on other sites More sharing options...
WiseCleaner Posted May 26, 2016 Report Share Posted May 26, 2016 No, disk defragmentation won't corrupt the hidden files/folders. Link to comment Share on other sites More sharing options...
robertwnielsen Posted June 1, 2016 Report Share Posted June 1, 2016 I have a folder on a USB drive that I keep hidden. Today, I needed to access it to move some new files into it, but when I tried to hide it again, I received an error screen that simply said:"Cannot Hide Folder. Error message:" Weirdly, there was nothing after 'Error message.' Thanks for any help. Robert Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted June 3, 2016 Report Share Posted June 3, 2016 I have a folder on a USB drive that I keep hidden. Today, I needed to access it to move some new files into it, but when I tried to hide it again, I received an error screen that simply said: "Cannot Hide Folder. Error message:" Weirdly, there was nothing after 'Error message.' Thanks for any help. Robert Hey, Please check if a file is in use. Before you hide a folder, you should ensure all files in that folder are not in use. Link to comment Share on other sites More sharing options...
geogeo.gr Posted June 14, 2016 Report Share Posted June 14, 2016 Greek translation update to WFH Pro 3.36 WFH_greek.zip Link to comment Share on other sites More sharing options...
leoviale Posted June 18, 2016 Report Share Posted June 18, 2016 Will it be possible to add a "minimize to taskbar" option? Sometimes I close the software thinking it'll still be active in the taskbar and it closes completely. THanks! Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted June 27, 2016 Report Share Posted June 27, 2016 Hey leoviale, Thanks for your suggestion, I will send it to the developer team. Link to comment Share on other sites More sharing options...
geogeo.gr Posted September 13, 2016 Report Share Posted September 13, 2016 Greek translation update to WFH Pro 3.41 WFH_greek.zip Link to comment Share on other sites More sharing options...
