Alisa02
EdbMails EDB to PST Converter
EdbMails EDB to PST Converter Software which allow you to nicely Recover EDB emails mailbox to PST File as well as repair corrupt exchange server database.It can easily findthe EDB location and fix all the issues of EDB file to makes it useable into outlook file. It gives the complete examination of Exchange Databases files to recover and alteration process.This tool can easily export exchange mailbox to PST from Outlook Without distressing the size of Exchange EDB files and easily convert EDB files into PST, EML, MSG, Text and HTML file format with convert all reclaimed Email items into outlook file with along email header, email equities or attachments too. Splitting the generous size of PST file up to 20GB or more during conversion time.
•    Easily converts EDB to PST files &Restore deleted mailboxes directly from EDB file.
•    It is compatible with all MS Outlook 2000, 2002, 2003, 2007, 2010, 2013 and latest 2016.
•    It compatible with all the windows OperatingSystems like Windows XP, Vista, 7, 8, 8.1 and 10.
•    Also, it provides recovery of all the attachments including contacts and calendar.
EdbMails Convert EDB to PST  is the only available software which allows you to convert and export Online as well Offline, both, EDB file to PST format.
For more information visit: https://www.edbmails.com
Many EDB users don’t know that How to Convert EDB to PST? But now it’s their time to convert EDB file to PST file easily with the help of Enstella EDB to PST Converter Software. This software has very attractive and easy to use steps because it will help you during the conversion process through its video provided in the website. This software is capable to convert EDB file to any format such as PST/ EML/ MSG and HTML. It works on whole Window Versions like: Win 2000, Win7 x32, Win 7 x64, Win 98, Win Server, Win Vista, Win Vista x64, Win XP, Win 8, Win 8.1, and Win 10.
The ideal way to restore data from damaged .EDB Files when storage database is inconsistent is by using EDB to PST Converter tool. This smartly programmed software can extract the user mailboxes from damaged EDB files that can be saved in new working PST files. This tool also allows user to search the required emails from EDB files that needs to be restored in PST files. To get more info, Click : https://www.recoveryfix.com/exchange-server-recovery.html
Shoviv EDB to PST Converter software provides an ideal solution to recover deleted items and recover corrupted EDB files without tampering any content. This tool also works to export EDB files into Outlook PST, EML, MSG, Office 365, and Live Exchange. It has a free trial version and a good technical support team as well.
Read More: https://www.shoviv.com/convert-edb-to-pst.html
