richardharrison
EdbMails EDB to PST Converter tool
EdbMails EDB to PST exchange recovery tool is capable of settling all corruption problems that maybe encountered by an exchange database, such as, dirty shutdown , JET errors, corruption due to disk failure,  header file issues and so on.
The best thing about EdbMails is that it has a well organized user interface that lets you preview all the contents before export. Most exchange administrators would agree that the exchange database corruption is a plague that they intend to keep in check and perfect medicine to fight this plague is using EdbMails.
In addition to reliable exchange recovery, EdbMails will let you directly migrate  exchange database to on premises exchange server or Office 365. What's more novel about using EdbMails is that it doesn't alter the data contained in original EDB file in anyway. Most versions of Microsoft Outlook,Windows and Exchange servers are supported by EdbMails. To alleviate any doubts that you may have about the functioning of EDB to PST Converter, there is also a free version of the tool that lets you test out all EdbMails's features and export upto 30 items per folder/mailbox .
Kernel for EDB to PST Converter is another effective and more advanced software, by using it, you can easily convert EDB to PST file without facing any issues. It also helps to fix EDB corruption issues and recover all deleted or inaccessible data from healthy as well as corrupted EDB file. You can also use it to export EDB file to Outlook PST,  Live Exchange Server and Office 365. For more information, visit: https://www.nucleustechnologies.com/edb-to-pst.html
To good perform an excellent, restore of the mailboxes from the EDB to PST, I can suggest you to use RecoveryFix for Exchange Server Recovery tool. Users can easily recover all EDB mailbox items emails, attachments, drafts, permanently deleted email etc. into PST file format.
See video: https://youtu.be/13ofdbm5XmU
Get more information, visit from: https://www.recoveryfix.com/exchange-recovery-manager.html
Enstella EDB to PST Converter Tool productively perform task to repair damaged EDB file and also convert all elements EDB file to PST, EML, MSG and HTML formats and with all email properties as like: to, cc, bcc, time, date and subject etc. Using this program, user can convert all components: journal, task, calendars, inbox, items and appointments etc. This application offers to recover emails between two dates (“start dates to end date”). It works on whole MS Exchange EDB File version: 5.0 to 2016 & window version up to win 10 (32 & 64 bit).
Download Software: EDB to PST
Shoviv EDB to PST Converter is a complete solution which works to recover and convert EDB files into PST, EML, and MSG format. It also provides another solution to migrate EDB to Office 365 and Live Exchange mailbox. This tool also helps to save EDB data into HTML, RTF, Cal, vCal, and vCard format.
Read More: https://www.shoviv.com/convert-edb-to-pst.html
