Sign in to follow this
andrewpaul034
Inaccessible OST files and their solution
EdbMails OST to PST Converter software is considered as a one stop solution for the problems faced by users regarding the corrupted/damaged/crashed OST files.
outlook supports all the features of exchange server. when an user needs to add a person account of exchange to be configured with the MS Outlook user profile, then all of the statics are in sync with the MS Outlook. This is called as synchronization of OST with the ms exchange server.
another positive thing of this option is that it allows the user to access the OST documents in offline conditions also and files are made accessible even the outlook profile is not related with exchange server, but sometimes it will fails  to sync and then OST document cannot be available in MS Outlook. this breakpoint in connection among the server and client makes the OST in an unreachable condition.
Following are the reasons for corrupted OST files
  • The synchronization failure may leads to the OST files to get corrupted when an encryption key is lost from mailbox or MAPI
  • Whenever a new user creates a new outlook file or editing the existing profile without proper permission or without knowing how to create the profile might lead to a chances of getting the OST files corrupted.
  • Failure of MS Outlook or stoppage of synchronization while running the sync process may leads to OST files to get corrupted.
Solution-
The best solution suggested when an  user encounters the above mentioned reasons is to use a trustworthy third party tool which is capable of solving all the problems. EdbMails OST to PST Converter software is the tool which can do all the task without any hassle. this software uses a deep scanning technique and a sophisticated methodologies to encounter any kind of difficult situations if you want to keep your database in a safe hands then  download and install EdbMails OST to PST Converter software.
for more info visit- https://www.edbmails.com/pages/OST-to-PST-Converter.html
Get quicker application from provided link and converts all OST file items like- notes, contacts, journals, calendar, email header information (to, cc, bcc, date, time, from and subject etc.), appointments and zip attachments etc. into .pst and other formats like MSG/ EML/ PDF/ HTML and MBOX without loss of any information. PDS OST to PST Converter is capable to convert OST to Office 365 with complete mailbox items. This software perfectly works on below/ higher versions of Windows and MS Outlook.
Read More: http://perfectdatasolutions.blogspot.com/2015/12/outlook-ost-to-pst-2016.html
MailsDaddy OST to PST Converter is efficient and nice software for window users to perform batch OST to PST conversion simultaneously and save your valuable time. This is a very fast application which gives safest and most effective option to open OST mailbox data into a fresh new PST file that you can save at any desired location. It allows you export all header data, optimal body, Rich text and attachments from OST to PST file format. It preserves the original file structure and all data properties during the whole OST  to PST conversion process. The software is very reliable to export OST to PST format for Outlook. It consists of a user-friendly and simplified graphical user interface which is very friendly to both non-tech and tech users.
With the help of OST to PST Migration Software Users can convert unlimited OST files to PST file with all emails, contacts, calendars, task, notes, and appointments without difficulty. OST to PST Software supports any kinds of mail clients OST file to convert their emails messages into PST file.
Get Details: http://www.sametools.com/convert/ost/
You can convert corrupted or non corrupted OST file into multiple formats with the help of two convenient way first one is manually and the second one is a third party tool. If you are looking a proficient and cost-effective tool to convert OST file into PST format, then you can check OST to PST converter tool from Bitdataconversion.
Read For More Information: http://www.bitdataconversion.com/ost-to-pst-converter.html
