doulton Posted September 7, 2013 Report Share Posted September 7, 2013 Every time I log on,I get a pop up saying to upgrade the Abobe flash player,,I always uninstall,reinstall and than find the next log on ,the same warning. I have tried switching off Norton, Using the install run,and to save ,the program. A pop up always tells me it is now installed but as soon as I lpg on again its the same old message. I use IE10 Windows 7 Pro,and a fairly new PC. Any advice please Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted September 12, 2013 Report Share Posted September 12, 2013 Hi, sorry to reply you late. 1, Run Wise Care 365---System Tuneup---Startup Manager----Services, find out Adobe Flash Player Update Service, set it OFF 2, Or, you can click Start---type services.msc in search box and press Enter, find out Adobe Flash Player Update Service, double-click it, set its startup type as Disable / Manual Link to comment Share on other sites More sharing options...
doulton Posted September 28, 2013 Author Report Share Posted September 28, 2013 Hi, please excuse lateness due to severe illness. Still having the same old problem Tried all suggested remedies to no avail. Using Windows 7 IE 10 and Norton (cleared) I uninstall Flash player 11, Install latest version Pop up adobe window informs me FLASH PLAYER ios now installed. After every log out and reboot same old problem again. Any further ideas please. Thank you Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted September 29, 2013 Report Share Posted September 29, 2013 Please do a snapshot about the pop window and send to us. Link to comment Share on other sites More sharing options...
doulton Posted October 27, 2013 Author Report Share Posted October 27, 2013 Hi Again Still in trouble with adobe flash player,Will not stay installed, When I log off it disappears. I note that adobe has said it is trying to fix this problem ,is there any news yet.? Is there a similar program I can use. Thanks Link to comment Share on other sites More sharing options...
WiseCleaner Posted October 28, 2013 Report Share Posted October 28, 2013 Try following step to solve your problem. 1, click Start---type services.msc in search box and press Enter, find out Adobe Flash Player Update Service, double-click it, set its startup type as Disable / Manual 2, click Start---type task scheduler in search box and press Enter, (right-click My Computer----Manage-----Task Scheduler), find out Adobe Flasher Player Updater, disable it or delete it. Link to comment Share on other sites More sharing options...
