Karenjitkaur
Pst to applemail Converter
Migration of Windows Outlook PST File to Apple mail can be done with the manual method. User just needs some technical knowledge. However, In case if the user is not technically strong then they can use third party tool like Stellar PST to MBOX Converter for Mac.
Note: I don’t have any prior experience with this software so I suggest you use its demo version.
You can get its demo version from:     http://www.tools4recovery.com/pst-to-applemail-converter.html
When we are talking about the conversion of PST to MBOX format to access Outlook Data in Apple Mail, then you must need to use trustworthy utility PST to MBOX Converter. After the successful PST to MBOX Conversion, users can safely import PST files to MBOX without losing any data. It consists of various advanced features by which users can safely convert PST files to MBOX format. By using this utility, users are capable to batch convert PST files to MBOX format in a single click. Visit:- http://www.softakensoftware.com/eml-to-outlook-converter.html
There is no direct method to convert PST to EMLX format or Apple Mail Format. So, I would like to suggest to use Free PST to EMLX Converter. The tool provides the best solution with free of cost. It quickly converts all data of PST file to EMLX format for Apple Mail or Mac Mail Versions.
Beneficial Features of Free PST to EMLX Converter
1. Convert PST files with their attachments to EMLX format
2. Support to export multiple PST files into EMLX at once
3. Operable with all latest and old versions of Microsoft Outlook
4. Maintains data accuracy and properties of PST files
There are many options available in the market. but I will suggest you to use third party tool because this method is fastest and accurate.
As we know, PST is a common file format of MS Outlook for Windows. It is not supported by Apple mail or any other email clients. If you are looking to access your  MS Outlook database to Thunderbird or any other email clients, then you need a MAC PST to MBOX Converter for this Conversion. This tool helps to export all your data in pst format.
You can easily install this app in your Mac. Try free demo version of this tool to know about its working, after assurance you can go for paid one,  which has many advanced features.
For more detais :- http://www.toolscrunch.com/mac-pst-to-mbox-converter.html
By using the manual method you can convert PST file data to MAC.
Follow steps:
  • On the Outlook for Mac File menu, click Import.
  • Click Outlook Data File, and then click the right arrow.
  • Select a data file type, and then click the right arrow.
  • Locate the data file on your computer, and then click Import.
  • When the import process is complete, click Done.
Sometimes manual method doesn't work properly you can try the third party tool. Online PST to MAC Converter tool is perfect software to import PST to OLM.
Thank you!
