Perform the conversion of EML files to PST format using Mailsware EML to PST Converter. The tool has the capability to convert multiple EML files to PST format at once. With this software, you can easily convert EML emails to PST along with attachments. The tool provides the complete preview with the exact formatting.
Key Features of EML to PST Tool:
  • Bulk conversion facility.
  • No file size limitation.
  • Support for all Windows version.
  • Maintains all the properties.
  • Browse the required location.
EML to PST conversion is a easy process by which you can use Windows Live Mail EML files in MS Outlook. One of the solution to convert EML files is by exporting them to MS outlook. Open Your Windows Live Mail go to Export and click Email Messages.Select the items which you want to move and than finally click Finish. Your EML Messages, contacts and other data which you selected will be exported to MS outlook. Check the complete steps to convert EML to PST.  http://www.toolsbaer.com/eml-to-pst-conversion/
If you are searching a conversion tool that helps you to convert EML files to Outlook PST formatting in quick and easy manner and makes accessible all EML files into MS Outlook. I would suggest a third-party EML to PST Converter Tool to do this job. It has advance features and simple GUI that makes conversion process very easy. You can convert single or multiple EML files into PST format in just a single click without causing any changes or data loss.
Read more info at:- http://migrateemails.com/how-to-import-eml-to-outlook/
EML to PST Converter is a significant utility to solve all your doubts. It converts whole EML mailbox into an existing or fresh PST file without losing security. EML mailboxes consist of several items like emails, calendar, tasks, notes, journals, contacts and more. This is world's best and safest way to export all EML emails into MSG, PST and EML file formats for conversion and providing 100% recovery of data. Visit:- http://www.eml.tooutlookconverter.com/
If you are a Mac user then you should try this EML to PST Converter for Mac:- https://www.mailvita.com/eml-to-pst-converter-for-mac/
