OST to PST Converter- Migrate ost to office 365
ost to pst ost to pst converter ost to office 365 ost converter
  • Please log in to reply
6 replies to this topic
#1 jaydensmith1
jaydensmith1
    Advanced Member
  • Members
  • PipPipPip
  • 94 posts
Posted 05 May 2018 - 05:12 AM
Microsoft Outlook uses OST file to save and access data in offline mode. This Outlook offline data file (ost file) allows users to work in offline mode and save work data. Next time when the connection is available, MS outlook automatically synchronize all work and changes with Exchange Server. Here some time while working offline OST file damaged due to Outlook unusual shutdown or synchronization error and many others reasons. To fix OST file and recover all data, OST to PST Converter tool is the best option.  This Software not only recovers Outlook emails and other data from OST file but also convert to PST and many other formats. Here if you have an Office 365 subscription, then you can also export recovered data from Outlook OST file to your Office 365 account.
Download- https://vmail-ost-to...n.softonic.com/
  • TelemahU likes this
#2 luciferr
luciferr
    Advanced Member
  • Members
  • PipPipPip
  • 68 posts
Posted 12 May 2018 - 08:52 AM
By getting OST to PST software you can remove UN wanted OST file errors and fix them after that you can also convert OST file to PST outlook with all emails items i.e:- EML/MSG/HTML/MHTML/TXT/DOC/MBOX and outlook profile as well as also support all version of OST file as:- 5.0/5.5/2000/2003/2007/2010/2013 and 2016. Stella OST to PST Recovery software is smoothly recover damage corrupted exchange OST file and allows to save OST file data into working MS outlook with its emails properties like as:- Date & time, To, BCC, Subject, From, CC from (email sent from, subject of email).
For Further Detail Please visit here:-   https://gallery.tech...covery-ca00ddf2
#3 ralphmiller
ralphmiller
    Member
  • Members
  • PipPip
  • 16 posts
Posted 14 May 2018 - 11:24 AM
OST to PST converter tool export Outlook OST as PST, MSG, MBOX, EML, EMLX, vCard & vCal formats. This tool can also migrate all Outlook data from OST file to your Office 365 account and Live Exchange Server. The OST to PST Conversion process with this tool is very easy, quick & safe as well. Not any type of data loss risk while conversion process with this software.
Read More & Download - https://gallery.tech...verter-61d8ce0f
#4 sentluis31
sentluis31
    Advanced Member
  • Members
  • PipPipPip
  • 225 posts
Posted 14 May 2018 - 12:57 PM
To restore data from corrupt OST file and save as PST format, you can try Recoverydatatools OST to PST Converter. This software has the ability to quickly recover all data from Outlook OST file and safely convert to PST and also many other formats like MBOX, EML, EMLX, MSG files without loss of any data. You can recover and convert any size of OST file from all versions of Microsoft Outlook program. Download http://www.recoveryd...-converter.html
#5 barbarajames
barbarajames
    Advanced Member
  • Members
  • PipPipPip
  • 44 posts
Posted 15 May 2018 - 10:15 AM
Using vMail OST to PST Converter Tool, you can easily migrate Outlook OST data to your Office 365 account. This tool can convert OST to PST, EML, EMLX, MSG, MBOX, vCard & vCal file formats. OST to PST Converter supports any size of OST file from MS Outlook 2016, 2013, 2010, 2007 & all older versions.
#6 jenyfrendo
jenyfrendo
    Advanced Member
  • Members
  • PipPipPip
  • 61 posts
Posted 16 May 2018 - 07:47 AM
Use PDS OST to PST Converter Software which perfect solution to easily repair corrupt OST File data and high application to recover emails items folders data in secure way. This Utility assist you to convert OST File into Outlook PST File more other formats like as :- EML, HTML, MSG, MBOX and PDF with all emails properties like as :- ( To, CC, Bcc, Subject Date and Time ) Including all attachments/images contacts/calendars/videos/appointments/journals. This Tool easily split large PST File into small PST File 1 GB to 5 GB. This utility gives you naming convention option to save your data like as: - from” + subject date, Subject date, from”+ subject. It gives you demo option to save your 20 emails per folders. It works on all MS Outlook version from: - 97 to 2016
Read More Information about This Software :-  OST to PST Converter
#7 calorina
calorina
    Advanced Member
  • Members
  • PipPipPip
  • 56 posts
Posted 16 May 2018 - 10:15 AM
Download VOOK OST to PST COnverter for the safest and easiest migration of OST Files into PST. This software is the best solution to convert OST into PST Layout. Users can easily do this process without any efforts and access their OST Files into PST. This software supports all the versions of MS Outlook and converts more than one OST Files instantly.
Visit: - http://www.vooksoftw...com/ost-to-pst/
Also tagged with one or more of these keywords: ost to pst, ost to pst converter, ost to office 365, ost converter
