Ost To Pst Conversion
Recovery
  • Please log in to reply
9 replies to this topic
#1 salenagomes
salenagomes
    Member
  • Members
  • PipPip
  • 16 posts
Posted 23 April 2018 - 07:59 AM
If you have problems opening your .ost file, you can use the Inbox Repair tool (Scanpst.exe) to diagnose and repair errors  in your .ost file. The Inbox Repair tool (Scanpst.exe) can be used on your .ost file as well as Personal Folders file (.pst).
The tool scans the .ost or .pst file, and makes sure that the file structure is intact. It does not interact with your Inbox on the server running Exchange server in any way.
More Key Features: OST to PST Converter
*Instantly Convert OST to PST File
*Repair corrupt or inaccessible offline .ost files
*Show Preview of All Converted Emails in Free Version
*Save Converted Emails in PST, MSG, EML, RTF, HTML, and PDF formats
*No restriction on file size when converting OST to PST File
*Support all versions of MS Outlook and Exchange Server
*Use Free Trial Version
Free Version Available: Download Now
Just download the free trial version of OST to PST Converter software, free version is integrated with full featured rather
than to save data. In free trial version, user can repair corrupt OST file and also Convert OST emails to PST file.
Download link :-  http://www.recoverfi...conversion.html
  • Anthonymag and Aaronkew like this
#2 jenyfrendo
jenyfrendo
    Advanced Member
  • Members
  • PipPipPip
  • 61 posts
Posted 25 April 2018 - 06:44 AM
Wholly Solution for PDS OST to PST Converter Software that remove OST File errors and recover emails items folders file data .It convert OST file into Outlook PST file and more other formats such as :- MSG, HTML, EML, MBOX and PDF. By Taking help of This Tool you can helpfully repair OST emails and restore OST to Outlook formats with all email properties and attachments such as-: Contacts, Calendar items, Notes, Scheduled tasks, appointments, journals, drafts etc. (To, Cc, Bcc, Subject, Date & Time etc. This is simple solution for splitting large PST file into small PST file (1GB to 5GB). It provides naming convention option to save your data such as: - from”+ Subject date, subject date, from” + subject.
Read More Information about This Software  :-  OST to PST Converter
#3 JerryB
JerryB
    Advanced Member
  • Members
  • PipPipPip
  • 180 posts
Posted 26 April 2018 - 05:28 AM
OST to PST Converter software is an integrity tool that smartly work on corrupted OST file and recovered all mailbox data like emails, tasks, journals, contacts, calendars, etc. The software also provide three modes of recovery like Standard, Advanced and Deep Mode. With this software user can easily transfer all OST file data to Outlook PST or other files like MSG, EML, DBX, MBOX and HTML format.
Download free demo version of this tool here:- http://migrateemails...-to-pst-format/
#4 marcobrown
marcobrown
    Advanced Member
  • Members
  • PipPipPip
  • 35 posts
Posted 26 April 2018 - 09:44 AM
Hi
Hope you are doing well!
I earlier discuses about how to convert OST file to PST file format.You can see my answer via this link:http://forum.wisecle...rrupt-ost-file/
Thanks
Regards
Marco!
#5 salenagomes
salenagomes
    Member
  • Members
  • PipPip
  • 16 posts
Posted 02 May 2018 - 10:14 AM
Latest new version available OST to PST Converter software that deeply scan OST file and save OST as PST.S
uperb excellent OST to PST Converter Software is reliable and smart way to perfectly convert OST file into
PST with full conversion mode.
Download From here :-   http://www.osttopstconverter-tool.com/
#6 jaydensmith1
jaydensmith1
    Advanced Member
  • Members
  • PipPipPip
  • 94 posts
Posted 03 May 2018 - 05:55 AM
For fast and easy OST to PST conversion use vMail OST to PST Converter Tool. This tool can recover and restore every Outlook data from OST file and convert to PST file without loss of any data. You can use any size of OST file from different versions of MS Outlook Software for OST to PST conversion. I suggest you try Demo version of this software. In demo mode, you can recover & convert 30 emails per folder for free of cost from every OST file.
Download Demo Now- http://download.cnet...4-77746438.html
#7 alexaa
alexaa
    Member
  • Members
  • PipPip
  • 28 posts
Posted 04 May 2018 - 10:08 AM
eSoftTools OST to PST Converter Software is a very good Conversion Software which fastly available in the market. If your Outlook OST File get corrupted and damaged OST File and convert offline OST file to PST Outlook file, EML, MSG, HTML, EMLX, MBOX and vCard format.  OST to PST Software successfully convert OST file data included - inbox/outbox/sent mails/junk mails/journal/contact/calendar/task/notes and appointments.  And let users view all software functionality. OST to PST Software supports all MS Outlook file versions included- MS Outlook 2003, 2007, 2010, 2013, 2016.
get more info:-  http://www.esofttool...topstconverter/
#8 calorina
calorina
    Advanced Member
  • Members
  • PipPipPip
  • 56 posts
Posted 04 May 2018 - 11:49 AM
VOOK OST to PST Converter is the best approach for users to migrate OST documents in PST format and get access to their entire OST data after conversion also in Microsoft outlook. Without losing any data, users can set their desired location for the converted file. This software allows the full converion of OST Files into Outlook with all attachmnets like images, ppt. documents, etc.
#9 salenagomes
salenagomes
    Member
  • Members
  • PipPip
  • 16 posts
Posted 16 May 2018 - 10:59 AM
#10 sentluis31
sentluis31
    Advanced Member
  • Members
  • PipPipPip
  • 225 posts
Posted 18 May 2018 - 12:25 PM
Fix damaged OST file using Recoveydatatools OST to PST converter tool and recover all emails, contacts, calendars, attachments, tasks etc. Further, you can migrate recovered OST data to PST and many other formats like EML, EMLX, MSG, MBOX, vCard & vCal. You can convert any size of OST file from different versions of MS outlook. http://www.recoveryd...-converter.html
Also tagged with one or more of these keywords: Recovery
