PWT1000 Posted April 15, 2018 Report Share Posted April 15, 2018 Hello :-) I recently used a program called ‘Privazer' & I believe this has broken the Advanced Clean on C:\ only. Nothing happens when I click on it I have totally uninstalled (removing wise registry keys) re-installed Wise365 to no avail as I assume there are hidden registry keys used by yourselves so all info from the registry can't be removed to fix the problem. I've removed Privatizer, I normally have Macrium Reflect images of C:\ but I've messed with the Win 10 Spring Update etc & removed it so can’t image back without a lot of work. (BTW the issues occurred before I messed with MS Spring Update) Any help please?? Kind regards Paul RidgeViz, Aaronkew, ritaTen and 2 others 5 Link to comment Share on other sites More sharing options...
xilolee Posted April 17, 2018 Report Share Posted April 17, 2018 Hi PWT1000 - Paul. Run chkdsk c: /f from an elevated command prompt. At least twice. Link to comment Share on other sites More sharing options...
PWT1000 Posted April 18, 2018 Author Report Share Posted April 18, 2018 Hello: I tried running chkdsk c: /f which found errors but could not correct them. So, after some time I imaged back to the beginning of March & Wise365 was working fine. Thanks for the help! Thanks Paul ... Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted April 19, 2018 Report Share Posted April 19, 2018 Thanks xilolee Link to comment Share on other sites More sharing options...
