jenyfrendo
How to Convert OST (Offline Storage File) into PST
Lots of software available in online marketing which has ability to recover OST File errors and convert OST Data into PST but it is very difficult to choose one among thousands application therefore I give you information about best and affordable PDS OST to PST Converter Software thereby you can easily repair different kinds of OST File corruption issues which make OST Data unreadable and thereafter provide different format to convert OST Emails like as :-  PST/ EML/MSG/HTML/PDF and MBOX including with all attachment/ properties (to, cc, bcc, sent mail, draft), appointment , junk mails etc. It has available email filtering option to restore OST Emails between 2 dates “from date” to “to date”. With the conversion process of OST Mails to Outlook you can select split option to divide oversize of PST File into small PST File up to 5 GB that you can open recovered PST Data into whole MS Outlook (ANSI or UNICODE).
Note: - Demo version also available in this application which gives permission to restore 20 OST Emails into each format without any cost.
Read More Information about This Software :-  OST to PST Converter
Use vMail OST to PST converter to convert OST file to PST format. Users can also convert OST file to MBOX, MSG, EML, EMLX, EML, vCard & vCard file format according to their need. You can convert any size of OST file to any location using this software. Try Demo Version of the software which allows users to convert 30 mailboxes per folder for free of cost.
Download Now- https://vmail-ost-to-pst-converter.en.softonic.com/
If you are facing broken and inaccessible OST file then try ATS OST to PST Converter to make those files accessible, it can store the recovered OST database into EMLX, vCard, vCal, MSG, and MBOX, HTML, it support MS Outlook version 97, 98, 2000, 2002, 2003, up to 2016 and Office 365, it can migrate OST data into Live Exchange Server.
Visit more info:    OST to PST Converter
If you want the best solution that convert OST file to PST then you must download Indya OST to PST converter. This software is one of the best tool in the present time and it comes up with lots of advanced features such as:-
  • Convert unlimited OST file to PST at once
  • Export OST to PST along with the attached files
  • Import large size OST file to PST without corrupting
  • Supports all MS Outlook and Windows OS versions
  • Drag and drop option for users ease
  • Just three easy steps conversion process
  • 100% safe from virus or malware
Read more: https://www.universalhunt.com/articles/ost-to-pst-converter-to-export-ost-files-to-pst-with-attachments/16413
Step-1
Step-2
Step-3
Hi Jenyfrendo
If you are looking for a software to open your offline Exchange OST to PST in MS Outlook, try this best OST to PST Converter tool that allows to repair an offline Exchange OST file and export all mailbox from them into MS Outlook PST, EML, MBOX, MSG.This tool is available with demo version for free evaluation.
Thanks
Regards
Marco!
Below are the key features of OST to PST Converter which I am going to recommend here. Software supports in all Windows operating system such as in 10, 8, 7, XP, Vista, 2003, 2000, etc.
  • Performs OST recovery in Standard, Advanced and Deep mode.
  • Supports in MS Outlook 2016, 2013, 2010, 2007, 2003, 2002 etc.
  • Lets user to save OST files in PST, DBX, EML, MSG, etc. file format.
  • Compatible with all windows based OS.
  • Free Demo is available.
Read more: OST to PST Converter
