Convert EDB to PST Tool
Edb to Pst Converter
  • Please log in to reply
5 replies to this topic
#1 elviraperry
elviraperry
    Newbie
  • Members
  • Pip
  • 8 posts
Posted 13 April 2018 - 05:42 AM
EDB to PST Converter repairs corrupt or damaged Exchange EDB files and restores the mailboxes into Outlook PST file. You can easily view Mailbox data from the PST files using MS Outlook application.EDB to PST EDB to PST Converter tool  helps you to recover mails, images, attachments, drafts, calendar, journals, appointments, tasks, notes, etc.
from the damaged EDB files.
Its ease of use GUI enables you to preview recovered mail items.It is such simple software that a user  with less technology awareness can easily operate it without any difficulty.
With this product client can undoubtedly and just as split your recover PST file to little PST file from 1 GB to 5 GB. EDB to PST Converter software is the great solution to repair crashed EDB file in order to convert EDB file to PST file. It helps you to extract Exchange database to MS Outlook. EDB converter software perfectly convert data from EDB file into PST file.
EDB to PST Converter is designed to convert EDB files of MS Exchange into existing or new PST files and to transform several mailboxes from selected files at once.
Key Features:-
- Instantly Convert EDB to PST File
- Repair corrupt or inaccessible Exchange Server Data or EDB file
- Conversion of Single or Multiple EDB files into PSTs with just one click.
- Conversion of EDB files of all sizes to existing or newly created PST files
- Efficient exporting to all mailbox items into PST.
Know More Deep knowledge:-  http://www.filesreco...-converter.html
#2 jaydensmith1
jaydensmith1
    Advanced Member
  • Members
  • PipPipPip
  • 76 posts
Posted 14 April 2018 - 07:25 PM
Use vMail Exchange EDB to PST converter tool to recover data from corrupt EDB file and also convert EDB to PST, EML, EMLX, MSG, MBOX & vCard file format along with all mailboxes data (inbox, outbox, journals, contacts, tasks, notes, calendars, sent items etc). This tool runs smoothly in latest operating system Window 10.
#3 sentluis31
sentluis31
    Advanced Member
  • Members
  • PipPipPip
  • 186 posts
Posted 17 April 2018 - 08:44 AM
Convert EDB file format to PST file format with the help of EDB to PST conversion software. This software provides EDB users the full assistance to recover and convert all EDB file to pst file format. Read more visit here: http://www.recoveryd...-converter.html
#4 helengilbert473
helengilbert473
    Advanced Member
  • Members
  • PipPipPip
  • 54 posts
Posted 17 April 2018 - 11:43 AM
Download- EDB TO PST CONVERTER
#5 SteFun
SteFun
    Advanced Member
  • Members
  • PipPipPip
  • 68 posts
Posted 18 April 2018 - 08:29 AM
If you're looking for a solution to convert EDB to PST format, you should try the ExMerge.exe utility. It's a freeware tool provided by Microsoft that can extract email messages from the EDB files and save them into new PST files. The best part of this tool is that it supports corrupt EDB files. So before you can purchase any paid software, you must use the ExMerge.exe utility. Refer to this article to know more about the ExMerge.exe utility and how to use it - Convert EDB to PST Format by using ExMerge.exe Utility
#6 toresjessica
toresjessica
    Advanced Member
  • Members
  • PipPipPip
  • 78 posts
Posted 18 April 2018 - 09:13 AM
PDS EDB to PST converter providing extremely secure conversion which simply converts Exchange EDB files into healthy formats like PST, EML, HTML and other formats. This Software also works to Recover corrupted, unreadable EDB Email components like contacts/ inbox items/ notes/ journals/ calendars/ embedded images/ scheduled task/ and appointments etc within seconds. It provides Splitting feature which helps to break large PST files into Small PST files without damaging original data. The Software perfectly Support all window versions upto Win 10. Demo version also available for users to restore 25 emails in all folder into every required format at free of Cost.
Get more information : EDB Converter Software
Also tagged with one or more of these keywords: Edb to Pst Converter
