For using the tool, you don’t require having any technical knowledge; (EDB to PST Converter) you can safely convert  EDB to PST File by following simple steps.
This EDB to PST Recovery Software supports to recover multiple mailboxes of file and successfully restore exchange mailboxes to PST Outlook file with contacts, calendars, task, notes,  inbox items, outbox items, journals, draft and appointments etc.
EDB to PST Software is windows program that supports all windows versions such as- windows 10, windows8.1, windows8, windows7 and below versions. You can convert all exchange  server EDB files versions files upto 2013 into PST Outlook file supported all versions upto 2016 (32 and 64 bit).
Features:-
- Instantly Convert EDB to PST File
- Repair corrupt or inaccessible Exchange Server Data or EDB file
- Conversion of Single or Multiple EDB files into PSTs with just one click.
- Conversion of EDB files of all sizes to existing or newly created PST files
- Efficient exporting to all mailbox items into PST.
PDS EDB to PST Recovery is most reliable Tool to Recover Exchange EDB mailbox files along with Entire Email properties including Attachments, Calendar, Contact, schedule task, journals, embedded images, zip attachments, videos and appointments etc and it gives safe recovery process without harm any original data. This Software is also capable to convert EDB mailbox files into various formats like PST, EML, HTML and more with 100% accuracy. This Software gives Splitting feature to split large PST files into small PST files upto 5GB. It gives free Demo version to restore 25 emails in per folder into every supported at free of cost.
Get more information: EDB to PST Recovery
vMail EDB to PST converter is the perfect solution to repair corrupted EDB file and recover emails and other data from Exchange Server. This tool can quickly convert recovered emails to PST file, MBOX file, EML file & MSG file format. Try Demo Version of EDB to PST converter to convert 30 emails per folder for free from any size Exchange EDB file.
Try Now- https://gallery.technet.microsoft.com/office/EDB-to-PST-Converter-494ba803
Quickly download SysInspire Free Exchange Recovery Software that removes all errors and recover exchange users mailboxes data to PST Outlook file. It is safe tool that supports all MS Outlook versions and required installation of MS Outlook application to perform EDB to PST Conversion.
EDB to PST Recovery Software smoothly recovery of deleted folders emails of EDB file and successfully convert EDB file to PST Outlook file, MSG, EML, EMLX and HTML format with extract EDB file emails, contacts, calendars, task, inbox items, outbox items and appointments.
Try EDB to PST Converter Software Free demo version that shows all software conversion process and permits users save 25 emails per folders into every format at free of cost. Software supports all MS Outlook versions included - 97, 2000, 2002, 2003, 2007, 2010, 2013 and 2016.
Read more:-  http://www.sysinspire.com/edb-to-pst-converter/
Use Enstella EDB to PST Recovery Software which has very simple graphical users interface so users can handle this software very easily. EDB to PST Software specially designed for repairing corrupted Exchange EDB files and convert into HTML/ PST/ EML/ MSG. The software can easily handle large PST file and split into small PST files from 1GB to 5GB. This software can smoothly work in whole windows versions and Exchange.
Try Enstella EDB to PST Recovery free for demo versions but there are some restrictions users can save 25 mails in every folder into different format at free of cost.
Read More : http://www.edbtopst.enstella.com/
