kriket Posted April 6, 2018 Report Share Posted April 6, 2018 I have WRC-9 PRO and I have a problem when I scan and clean with WRC.I noticed that each time I scanned using FAST mode the hits seemed to be the same to me,so I did the following..I restarted my comp. Opened WRC and ran the FAST scan,copied all hits and how many in each category and cleaned,waited 10 minutes (not using computer)I ran the DEEP scan doing the same as before,copy,clean etc. restarted comp. opened WRC then ran the CUSTOM scan and again doing the same, In each of the scan modes the options were exactly the same.I closed computer for 10 or so minutes.I then opened my computer,opened WRC-PRO I then did the exact same procedure once again and after this was completed I saw that again and again the results for each were exactly the same. Michaeltrili, GoracV, TelemahU and 11 others 14 Link to comment Share on other sites More sharing options...
xilolee Posted April 8, 2018 Report Share Posted April 8, 2018 Without fixing them in any cases? Link to comment Share on other sites More sharing options...
kriket Posted April 25, 2018 Author Report Share Posted April 25, 2018 As I said ,I ran each scan one @ a time,cleaning,copying all the hits and would wait 10 minutes before running,the next scan mode until I ran ,cleaned and copied exactly the same in each (with exact same settings) and doing so 3 times each.Restarted computer and repeated the 3 scans same as before,and again I got the exact same results,same hits same amount I,d appreciate any advice TY . Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted April 26, 2018 Report Share Posted April 26, 2018 Hi, Generally Fast Scan and Deep Scan could not have same results. I noticed you have cleaned registry after each Scan, so the problem is some registry items were failed to cleaned.Please do a Fast Scan and clean, then run Fast Scan again (do not click Clean button, only Scan), then right click on a item and select Export to.Send this report to us.Thanks. Link to comment Share on other sites More sharing options...
karmar Posted March 25, 2019 Report Share Posted March 25, 2019 Was this resolved. I have 48 errors that wont clean, is this a problem with my pc. copy of WRC_Report.txt attached Thanks for any answers karmar WRC_Report.txt Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted March 26, 2019 Report Share Posted March 26, 2019 @karmar Hi, These registry entries were created by McAfee, wise registry cleaner doesn't have permission to delete them. You can delete them manually. Right click one item and chose "Open in registry editor", then you can press Delete to delete it. Link to comment Share on other sites More sharing options...
