Nancy
"Engine failed to start"
Hi,
After installation, when you first open Wise Anti Malware, you will see this window "Initialization engine... " it is downloading engine.
Did you see it?
Please open Wise Anti Malware folder, normally it is C:\Program Files\Wise\Wise Anti Malware\SavEngine\
Find this file avupdate.log and send it to us.
I had recently posted that the engine Wise Anti Malware " engine failed to start:. I uninstalled the program and downloaded it again and saved it to my desktop and reinstalled it, This time I paid closely to the instructions and waited for the "engine with its definitions to install completely  then I ran the program and did a full scan, it worked smoothly! I might add that although this program is compatible with "windows defender", you might want to disable any other malware protection while installing it. WISE PATIENCE is the KEY!
Hi guys,
Sorry for it.
Please try this way:
1, press Win+R, type services.msc
2, find Wise Anti-Malware service, right click on it and select Restart
3, when the service status change to Running, open wise anti malware to check it the engine works well
If restart service cannot fix this problem, please uninstall current file and REBOOT system (DO NOT forget this step), then install the latest version.
If you tried above methods but still get same problem, please send these 2 log files to us:
C:\Program Files\Wise\Wise Anti Malware\svr.log
C:\Program Files\Wise\Wise Anti Malware\SavEngine\avupdate.log
It still doesn't work. I'm going to update it to the new version 2.1.4 (from 2.1.2). I get this window:
I got it since the start, i.e. when I installed the program. I never got this window with other antimalware or antivirus programs. It asks to reboot: only antivirus programs ask this.
Edit: I updated the program, but it still can't start the engine. I disabled the firewall and the HOSTS file.
Win10 x64 (latest version, updated), DEP alwaysOn.
DISABLED: Win10 defender, Heimdal security pro, win10 firewall and HOSTS file.
  Reveal hidden contents
Hi xilolee,
Please send this file to us:
I also have the same issue w engine failed to start. It appears to download.
A black box comes up and flashes briefly. The program always has an error message about only partial protection.  I tried the fix from above. The same thing happened. Still no engine. Can't find the log. I turned off Avira and commode firewall. Tried again. Nothing. Note! I downloaded from one of the free giveaways of the day websites. Supposed to be free for a year. I would love to try it as the price is more reasonable than that other popular malware bytes one. Would you please look at my log IF I can find it? Edit***TO BE CLEAR. THERE ARE NO LOG FILES!
Edited by pckarma112
Add more info
If you have installed Avira, you cannot install Wise Anti Malware.
I've got the same problem (July 27, 2018) "Engine failed to start". The program begins the download of Avira's Engine and a little blue windows with a progress bar appears, then, when the download has terminated, a DOS windows flashes for a second on the screen and the download process restarts again. After a cycle of 4 downloads the program ceases to try to start the Engine. The Malware Scanner is unusable, but some other program's options work.
The file C:\Program Files\Wise\Wise Anti Malware\SavEngine\avupdate.log  DOES NOT EXIST after a "normal" installation. I've discovered that it can be generated running manually "avupdate.exe" as Admnistrator, but looks like it's the only effect of running this executable and looks like it has to be done only manually. If you run it as a normal (not-Administrator) user nothing happens at all.
When run as Admin "avupdate.exe" hangs and nothing happens except for the generation of a log file.
Here's the content of the log file generated as described before:
27/07/2018 12:11:53 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: Avupdate Version: 2.2.0.57
27/07/2018 12:11:53 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: Operating System: WINDOWS 8.1 64 BITS
27/07/2018 12:11:53 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: Installation Directory: .
27/07/2018 12:11:53 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: Backup Directory: .\avupdate_backup
27/07/2018 12:11:53 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: Temp Directory: .\tmp\avupdate_tmp_PSCByG
27/07/2018 12:11:53 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: Cache Modules Directory: .\idx
27/07/2018 12:11:53 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: Proxy settings: Direct connection
27/07/2018 12:11:53 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: Downloading http://132.148.133.59/AviraServerMirror/mirror/idx/master.idx to .\tmp\avupdate_tmp_PSCByG\idx\master.idx
27/07/2018 12:11:54 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: Downloading http://132.148.133.59/AviraServerMirror/mirror/idx/savapi4lib-win32-en.info.gz to .\tmp\avupdate_tmp_PSCByG\idx\savapi4lib-win32-en.info.gz
27/07/2018 12:11:54 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: Downloading http://132.148.133.59/AviraServerMirror/mirror/idx/xvdf.info.gz to .\tmp\avupdate_tmp_PSCByG\idx\xvdf.info.gz
27/07/2018 12:11:55 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: WARNING: Detected local cache corruption. Activating force-update behaviour
27/07/2018 12:11:55 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: Downloading http://132.148.133.59/AviraServerMirror/mirror/idx/xvdf.info.gz to .\tmp\avupdate_tmp_PSCByG\idx\xvdf.info.gz
27/07/2018 12:11:55 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: Downloading http://132.148.133.59/AviraServerMirror/mirror/idx/ave2-win32-int.info.gz to .\tmp\avupdate_tmp_PSCByG\idx\ave2-win32-int.info.gz
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: Downloading http://132.148.133.59/AviraServerMirror/mirror/idx/savapi4oalib-win32-en.info.gz to .\tmp\avupdate_tmp_PSCByG\idx\savapi4oalib-win32-en.info.gz
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\aevdf.dat 8.14.58.26 != 8.15.2.28
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00000.vdf 7.14.1.132 != 7.15.0.32
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00001.vdf 7.14.18.244 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00002.vdf 8.14.39.30 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00003.vdf 8.14.43.156 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00004.vdf 8.14.46.210 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00005.vdf 8.14.49.50 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00006.vdf 8.14.49.122 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00007.vdf 8.14.50.78 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00008.vdf 8.14.50.188 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00009.vdf 8.14.52.52 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00010.vdf 8.14.52.150 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00011.vdf 8.14.53.36 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00012.vdf 8.14.53.170 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00013.vdf 8.14.54.56 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00014.vdf 8.14.54.232 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00015.vdf 8.14.55.94 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00016.vdf 8.14.55.160 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00017.vdf 8.14.55.200 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00018.vdf 8.14.56.196 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00019.vdf 8.14.57.100 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00020.vdf 8.14.57.228 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00021.vdf 8.14.39.30 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00022.vdf 8.14.39.30 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00023.vdf 8.14.39.30 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00024.vdf 8.14.39.30 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00025.vdf 8.14.39.30 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00026.vdf 8.14.39.30 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00027.vdf 8.14.39.30 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00028.vdf 8.14.39.30 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00029.vdf 8.14.39.30 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00030.vdf 8.14.39.30 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00031.vdf 8.14.39.30 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00032.vdf 8.14.39.30 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00033.vdf 8.14.39.30 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00034.vdf 8.14.39.30 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00035.vdf 8.14.39.30 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00036.vdf 8.14.39.30 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00037.vdf 8.14.39.30 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00038.vdf 8.14.39.30 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00039.vdf 8.14.39.30 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00040.vdf 8.14.39.30 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00041.vdf 8.14.39.30 != 8.15.0.146
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00042.vdf 8.14.57.230 != 8.15.1.96
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00043.vdf 8.14.57.232 != 8.15.1.98
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00044.vdf 8.14.57.234 != 8.15.1.100
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00045.vdf 8.14.57.236 != 8.15.1.102
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00046.vdf 8.14.57.238 != 8.15.1.104
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00047.vdf 8.14.57.240 != 8.15.1.106
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00048.vdf 8.14.57.242 != 8.15.1.108
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00049.vdf 8.14.57.244 != 8.15.1.110
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00050.vdf 8.14.57.246 != 8.15.1.112
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00051.vdf 8.14.57.248 != 8.15.1.114
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00052.vdf 8.14.57.250 != 8.15.1.116
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00053.vdf 8.14.57.252 != 8.15.1.118
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00054.vdf 8.14.57.254 != 8.15.1.120
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00055.vdf 8.14.58.0 != 8.15.1.122
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00056.vdf 8.14.58.2 != 8.15.1.124
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00057.vdf 8.14.58.4 != 8.15.1.126
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00058.vdf 8.14.58.6 != 8.15.1.128
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00059.vdf 8.14.58.8 != 8.15.1.150
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00060.vdf 8.14.58.10 != 8.15.1.170
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00061.vdf 8.14.58.12 != 8.15.1.190
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00062.vdf 8.14.58.14 != 8.15.1.192
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00063.vdf 8.14.58.16 != 8.15.1.194
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00064.vdf 8.14.58.18 != 8.15.1.198
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00065.vdf 8.14.58.20 != 8.15.1.200
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00066.vdf 8.14.58.22 != 8.15.1.202
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00067.vdf 8.14.58.24 != 8.15.1.204
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00068.vdf 8.14.58.26 != 8.15.1.206
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00069.vdf 8.14.57.228 != 8.15.1.208
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00070.vdf 8.14.57.228 != 8.15.1.210
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00071.vdf 8.14.57.228 != 8.15.1.212
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00072.vdf 8.14.57.228 != 8.15.1.214
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00073.vdf 8.14.57.228 != 8.15.1.216
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00074.vdf 8.14.57.228 != 8.15.1.218
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00075.vdf 8.14.57.228 != 8.15.1.220
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00076.vdf 8.14.57.228 != 8.15.1.222
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00077.vdf 8.14.57.228 != 8.15.1.224
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00078.vdf 8.14.57.228 != 8.15.1.226
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00079.vdf 8.14.57.228 != 8.15.1.228
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00080.vdf 8.14.57.228 != 8.15.1.230
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00081.vdf 8.14.57.228 != 8.15.1.232
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00082.vdf 8.14.57.228 != 8.15.1.234
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00083.vdf 8.14.57.228 != 8.15.1.236
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00084.vdf 8.14.57.228 != 8.15.1.238
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00085.vdf 8.14.57.228 != 8.15.1.240
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00086.vdf 8.14.57.228 != 8.15.1.242
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00087.vdf 8.14.57.228 != 8.15.1.244
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00088.vdf 8.14.57.228 != 8.15.1.246
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00089.vdf 8.14.57.228 != 8.15.1.248
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00090.vdf 8.14.57.228 != 8.15.1.250
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00091.vdf 8.14.57.228 != 8.15.1.252
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00092.vdf 8.14.57.228 != 8.15.1.254
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00093.vdf 8.14.57.228 != 8.15.2.0
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00094.vdf 8.14.57.228 != 8.15.2.2
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00095.vdf 8.14.57.228 != 8.15.2.4
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00096.vdf 8.14.57.228 != 8.15.2.6
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00097.vdf 8.14.57.228 != 8.15.2.8
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00098.vdf 8.14.57.228 != 8.15.2.10
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00099.vdf 8.14.57.228 != 8.15.2.12
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00100.vdf 8.14.57.228 != 8.15.2.14
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00101.vdf 8.14.57.228 != 8.15.2.16
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00102.vdf 8.14.57.228 != 8.15.2.18
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00103.vdf 8.14.57.228 != 8.15.2.20
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00104.vdf 8.14.57.228 != 8.15.2.22
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00105.vdf 8.14.57.228 != 8.15.2.24
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00106.vdf 8.14.57.228 != 8.15.2.26
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00107.vdf 8.14.57.228 != 8.15.2.28
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00108.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00109.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00110.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00111.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00112.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00113.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00114.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00115.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00116.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00117.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00118.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00119.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00120.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00121.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00122.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00123.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00124.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00125.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00126.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00127.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00128.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00129.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00130.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00131.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00132.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00133.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00134.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00135.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00136.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00137.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00138.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00139.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00140.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00141.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00142.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00143.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00144.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00145.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00146.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00147.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00148.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00149.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00150.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00151.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00152.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00153.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00154.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00155.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00156.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00157.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00158.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00159.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00160.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00161.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00162.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00163.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00164.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00165.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00166.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00167.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00168.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00169.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00170.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00171.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00172.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00173.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00174.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00175.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00176.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00177.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00178.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00179.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00180.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00181.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00182.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00183.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00184.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00185.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00186.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00187.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00188.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00189.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00190.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00191.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00192.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00193.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00194.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00195.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00196.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00197.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00198.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00199.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00200.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00201.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00202.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00203.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00204.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00205.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00206.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00207.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00208.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00209.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00210.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00211.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00212.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00213.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00214.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00215.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00216.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00217.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00218.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00219.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00220.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00221.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00222.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00223.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00224.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00225.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00226.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00227.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00228.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00229.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00230.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00231.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00232.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00233.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00234.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00235.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00236.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00237.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00238.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00239.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00240.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00241.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00242.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00243.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00244.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00245.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00246.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00247.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00248.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00249.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00250.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00251.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00252.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00253.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00254.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\xbv00255.vdf 8.14.57.228 != 8.15.1.94
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\aecore.dll 8.3.15.4 != 8.3.16.4
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\aegen.dll 8.1.8.330 != 8.1.8.332
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\aeheur.dll 8.1.6.294 != 8.1.6.358
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\aeoffice.dll 8.4.5.8 != 8.4.6.4
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\aepack.dll 8.4.2.94 != 8.4.3.4
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\aescn.dll 8.3.8.2 != 8.3.8.4
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\aescript.dll 8.3.4.94 != 8.3.7.24
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\aeset.dat 8.3.50.52 != 8.3.52.34
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: .\aeheur_agen.dat 8.0.0.0 != 8.7.20.1122
27/07/2018 12:11:56 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: #1: Downloading http://132.148.133.59/AviraServerMirror/mirror/x_vdf/aevdf.dat.gz to .\tmp\avupdate_tmp_PSCByG\x_vdf\aevdf.dat.gz
27/07/2018 12:11:57 DESKTOP-UNMDTBV avupdate.exe[800]: UPD: INFO: #2: Downloading http://132.148.133.59/AviraServerMirror/mirror/x_vdf/xbv00000.vdf.gz to .\tmp\avupdate_tmp_PSCByG\x_vdf\xbv00000.vdf.gz
Instead here's the content of "srv.log":
WISE  ReportSvcStatus 4
WISE  GetMessage 464
WISE  savapi load error-----------
WISE  Send States 105 0
WISE  Send States 10c -1
WISE  Send States 109 0
WISE  GetMessage 405
WISE  DoRecvMessage 109 1 207
WISE  GetMessage 405
WISE  DoRecvMessage 109 1 204
WISE  GetMessage 113
WISE  DoSavapiUpdate
WISE  GetMessage 464
WISE  Send States 107 0
WISE  m_OaEngine.SavapiInit 33
WISE  Send States 109 33
Please fix this problem, I'd really like to test your software....
The folder C:\Program Files\Wise\Wise Anti Malware\SavEngine\ does not contain a file "avgio.dll", it can be found only inside a subdirectory:
C:\Program Files\Wise\Wise Anti Malware\SavEngine\on_access\win64\win8\avgio.dll (I've chosen Win 8 but I run Windows 10 OS, but there's not a Win 10 folder anywhere).
Copied it and reboot but it doesn't work, just the same "Engine failed to start".
svr.log has changed, here's the new version:
WISE  GetMessage 464
WISE  m_OaEngine.SavapiInit 2009
WISE  Send States 109 2009
1, open C:\Program Files\Wise\Wise Anti Malware\SavEngine\on_access\
2, right click on on-access-drivers-uninstall.cmd and choose Run as administrator
3, reboot system
4, open C:\Program Files\Wise\Wise Anti Malware\SavEngine\on_access\
5, right click on on-access-drivers-install.cmd and choose Run as administrator
6, reboot system again.
3, reboot system
Thanks for this.
