Outlook OST to PST conversion
ost to pst conversion ost to pst converter
  • Please log in to reply
11 replies to this topic
#1 barbarajames
barbarajames
    Member
  • Members
  • PipPip
  • 26 posts
Posted 27 March 2018 - 08:02 AM
For best performance in OST to PST conversion, you must try vMail OST to PST converter software. You can easily convert outlook OST file to PST format as well as MBOX, MSG, EML, vCard, vCal & EMLX format without any data loss. vMail OST to PST converter tool supports Microsoft Office 2000, 2003, 2007, 2010, 2013 & 2016 Outlook OST file in Windows XP, 7, 8, 8.1 & 10. Read more- https://goo.gl/j2386W
Try demo version of the software and convert 30 items per folder for free with the preview of the data.
Download Now
#2 selvi
selvi
    Advanced Member
  • Members
  • PipPipPip
  • 34 posts
Posted 28 March 2018 - 11:09 AM
Hi
If you are looking for a tool for Exchange OST to PST Conversion then try this recommendation. As this software is well appropriate for the users who all are not so much strong in technical terms. It is designed with a simple and user-friendly interface.
Thanks
Selvi
#3 shivguptag
shivguptag
    Advanced Member
  • Validating
  • PipPipPip
  • 110 posts
Posted 29 March 2018 - 09:18 AM
To convert OST to PST file, you can get the help of an OST to PST conversion software. The software also allows you to repair corrupt OST file and recover the stored data without facing any issues. For any other queries about the tool, visit: https://www.converto...pstfree.org/en/
#4 markronson493
markronson493
    Member
  • Members
  • PipPip
  • 22 posts
Posted 29 March 2018 - 10:43 AM
Hi,
If you are looking for an easy and safe Free OST to PST Conversion, Then I would suggest to try this Free OST to PST Converter Tool.
It is one of the best tools and provides easy and user-friendly step-to-step guide for those users who want to Convert OST to PST without losing their original and valuable data.
Hope this will help everyone!
#5 kagasgeorge
kagasgeorge
    Advanced Member
  • Members
  • PipPipPip
  • 83 posts
Posted 05 April 2018 - 11:45 AM
Get recover your OST quickly right after got problem without wasting your time by using GSTECH Outlook OST to PST Converter Software
FREE DOWNLOAD for 2016/2010/2013 Outlook OST to PST Recovery Tool
READ MORE
https://gallery.tech...verter-6c5ba947
#6 alinakenvin
alinakenvin
    Member
  • Members
  • PipPip
  • 23 posts
Posted 06 April 2018 - 10:36 AM
OST To PST Converter
Wonderful program for OST File recovery and OST to PST Conversion just download the successive and best file name as OST to PST Converter Software that fix all corruption issues, repair damaged OST file and convert OST File to PST, EML, MSG, HTML and many more forma with maintains each and every items from all OST mailboxes such as- emails, contacts, calendars, task, notes, inbox items, outbox items and appointments. Software works on all MS Outlook versions upto 2016 (32 and 64Bit.)
#7 jaydensmith1
jaydensmith1
    Advanced Member
  • Members
  • PipPipPip
  • 72 posts
Posted 09 April 2018 - 05:36 PM
Use Best OST to PST converter to export OST data to PST file and access your account emails, calendar, contacts and other items accessible through Outlook. With free Demo version of OST to PST converter tool 30 items for each folder of OST file.
Download - https://goo.gl/jE6DHS
#8 luciferr
luciferr
    Advanced Member
  • Members
  • PipPipPip
  • 59 posts
Posted 10 April 2018 - 06:56 PM
Stella gives you dynamic OST to PST software which applicable to recover all message from OST file like as:- contact/calendar/journal/notes and attachment as well as also support whole version of OST file like as:- 5.0/5.5/2000/2003/2007/2010/2013 and 2016. Stella OST to PST Converter conversion software has latest technology to fix OST file errors and convert OST to PST with other format like as:- EML/MSG/EMLX/DOC and HTML and also split large size of recovered PST file into small outlook PST file upto 5GB.
See more detail from here:- http://stellaosttops...ry.blogspot.in/
#9 jenyfrendo
jenyfrendo
    Advanced Member
  • Members
  • PipPipPip
  • 45 posts
Posted 14 April 2018 - 10:20 AM
PDS OST to PST Converter Software is superb great method for recovering OST file delete emails and restore OST file to PST file with provides best facility for filtering the messages” start date and ending date” for converting OST database into Outlook PST file.  This technology easily convert OST File into Outlook PST File more additional formats such as: - HTML,MSG, EML, MBOX and PDF with all emails properties like as (TO, CC, BCC, Subject date and time) including all attachments/ journals/ images/ contacts/calendars/ videos/ appointments. This Software provides demo facility to save your 20 emails per folders. It works on all MS outlook version from 97 to 2016.
 Read More Information about This Software :-  OST to PST Converter Software
#10 kagasgeorge
kagasgeorge
    Advanced Member
  • Members
  • PipPipPip
  • 83 posts
Posted 14 April 2018 - 05:42 PM
Grab Outlook OST to PST Converter Tool now via GSTECH platform which is more assisting for all OST users users who lost their emails from working OST file and got disturbed.
Be quick to get Outlook OST to PST Freeware Tool now to recover entire lost emails from Offline OST file and then convert further all emails into healthier formats at no cost.
Free Download for Outlook OST to PST Freeware Tool
https://gallery.tech...T-File-b73221f8
#11 scarlettjones
scarlettjones
    Member
  • Members
  • PipPip
  • 15 posts
Posted 18 April 2018 - 10:51 AM
To perform Outlook OST to PST Conversion you take help of Mailsware OST to PST Converter. This tool gives the 100% assurance to convert OST file to PST completely with exact formatting. It supports to export any size of OST file without any limitations. You can download the software with any Windows OS versions.
Know more and Download Tool
#12 sentluis31
sentluis31
    Advanced Member
  • Members
  • PipPipPip
  • 186 posts
Posted 20 April 2018 - 09:18 AM
This intuitive OST to PST conversion tool is inserted with unique technology that helps in extracting data from OST database and then changes it to healthy PST file. Get more details visit here: http://www.recoveryd...-converter.html
Also tagged with one or more of these keywords: ost to pst conversion, ost to pst converter
